Uprev Osiris Tuner With base model question
Old Feb 1, 2012 | 01:55 PM
  #61
AZHR's Avatar
AZHR
Originally Posted by e30cabrio
This is the base ecu file that tells the computer what model car you have.
can you make a how to on this? or give me a pm on all the stuff needed? i have a 08 base and would love me some cruise. especially since i drive from phx to albq to tucson often...
edit: and where did you buy this stuff. i read the whole thread, im pretty sure i skipped it lol...
Old Feb 1, 2012 | 02:00 PM
  #62
e30cabrio's Avatar
e30cabrio
Everything you need is in post 55:
Installed steering wheel controls. Installed clutch pedal cruise switch, installed brake pedal cruise switch, installed cal file cf41e over cal file cf43d. I have no lights on my dash but cruise, accel, decel all work!!!!!!!!!!!!
That is all you need.
Since you are in Phoenix after you install these three switches (that on my 06 connected to the hanging there wiring and worked with 08 steering wheel switches) go to Xact Dyno in Tempe and Tim will get it done for you.
ABC Nissan here in Phoenix gives 30% off call parts, as for George.
Old Feb 1, 2012 | 02:15 PM
  #63
AZHR's Avatar
AZHR
nice! thanks alot! i cant wait to have cruise, f the lights lol. im happy my foot will get some rest finally... lol
Old Feb 1, 2012 | 02:18 PM
  #64
e30cabrio's Avatar
e30cabrio
I understand, I got my car 5/10 with 56k and just turned 90k. I drive long distances daily and am loving cruise!
Old Feb 1, 2012 | 02:23 PM
  #65
AZHR's Avatar
AZHR
nice, oh one more thing, did you mount the controls to the steering wheel? or just mounted them some where else?
Old Feb 1, 2012 | 02:34 PM
  #66
e30cabrio's Avatar
e30cabrio
All the hardware is 100% Nissan OEM:
Still working on the audio controls.
Old Feb 1, 2012 | 02:41 PM
  #67
AZHR's Avatar
AZHR
sweet, is there a how to remove any where on here? or do they just pop right off?
Old Feb 1, 2012 | 02:45 PM
  #68
e30cabrio's Avatar
e30cabrio
I did over a year ago with with the wheel off the car. I think there is a small screw on the back of each pod.
Old Feb 2, 2012 | 06:43 AM
  #69
Junkster's Avatar
Junkster
So are you saying that even though you got the cruise to work you still have lights on your dash? or you were able to get those to come off as well?
Old Feb 2, 2012 | 06:52 AM
  #70
e30cabrio's Avatar
e30cabrio
From what I have been told, the base has no leds behind the bezel on the dash of the things it does not have. I have all cruise function except lights on the dash.
Here is the brake switch. When the brake is off it is pushed, closing the circuit. When you hit the brake it releases opening the circuit turning cruise off. The clutch is the same deal.
Old Feb 3, 2012 | 12:01 PM
  #71
fla350tt's Avatar
fla350tt
Originally Posted by fla350tt
Well I installed a gtm turbo kit and it uses the osiris reflash on a base model z. ever since i did the reflash i have had an error code for the cruise switch, which I do not have. so the ecm is now looking for the switch. so I am about a minute away from ordering the switch and trying it. I be in touch with the results. I would love cruise since i am 6'2" and sitting in the z for any more than 30 min. makes my foot fall asleep.
cruise switch ordered, hopefully will have by the weekend
My cruise is working, just had to add the cruise buttons on the steering wheel and the cancellation swithes for the break & clutch pedal. It really is hard to believe that a company did not figure this out a long time ago...
Old Feb 4, 2012 | 11:55 AM
  #72
fla350tt's Avatar
fla350tt
well my cruise only works up to 50 mph for some reason. fix one problem and another pops up.
Old Feb 5, 2012 | 03:36 AM
  #73
e30cabrio's Avatar
e30cabrio
That is odd. The fastest I have set it to is 80 but I have been able to use accel and go a bit faster to pass.
Old Feb 6, 2012 | 01:09 AM
  #74
fla350tt's Avatar
fla350tt
well I did some testing and found my problem. It is because my TPMS light is on, I think the wheel sensors are bad(dead batteries). This is another pain in the butt problem for for Z's.
Old Feb 6, 2012 | 08:32 AM
  #75
IfastR's Avatar
IfastR
that would affect cruise control??
Old Feb 6, 2012 | 11:37 AM
  #76
fla350tt's Avatar
fla350tt
It's a safety feature. The computer thinks I have flat tires
Old Feb 13, 2012 | 08:51 AM
  #77
Imnu2dis's Avatar
Imnu2dis
Did you have to change the ECU file like the other member did?
Old Feb 13, 2012 | 08:59 AM
  #78
seymore4's Avatar
seymore4
Professional
My TPMS light has been on for over a year since I put on aftermarket rims... my cruise control works just fine
Old Feb 13, 2012 | 09:10 AM
  #79
ian99rt's Avatar
ian99rt
I started a DIY thread for this bc its a little off topic. I'm waiting on the cruise enabled Rom before I finish it up.
I put my tpms sensors back in this weekend just to be sure all testing will be good.
Old Feb 13, 2012 | 09:27 AM
  #80
fla350tt's Avatar
fla350tt
Yes my computer has an Osiris reflash. It is from GTM for the twin turbo kit and I do not have any access to the files in the reflash
