Uprev Osiris Tuner With base model question
Old Nov 18, 2010 | 07:38 AM
silents1ick's Avatar
silents1ick
Default Uprev Osiris Tuner With base model question
hey guys i tried to find info online but had no luck, i thought i would post up here maybe some1 here can help me out...
I wont Osiris Tuner @ znationals this year, i finally got everything and the rom file...
i followed the instruction on reflashing the ECU and all and everything worked fined, car seems to run better then b4 just with the reflash feels like i some how got more torque but not sure... FOr the refrence
i have 06 350z Base 6spd
mods: Stillen HFC/True dual exhaust.
Z1 plenum spacer
Injen Intake
part not installed yet
Stillen headers
AMS pullies on the way(hopefully, ordered em during Znationals at
Z1, still waiting on them)
anyways so the main problem it does have 5 maps on it but i dont how in the blue hell would i be able to use it without traction control switches... i read in the manual and it says only way to swap through the maps is by cruize control switches...
has any one here figured out another way to switch through the maps??
im sorry if this topic has been posted b4 but i tried to search couldnt find, if it has already been discused b4 please guide me to the thread.
Thanks for any help in advance...
Old Nov 18, 2010 | 10:10 AM
Wu-Watt's Avatar
Wu-Watt
I'm in the same boat as you. I'm pretty sure were SOL....
Old Nov 18, 2010 | 10:13 AM
Steve-O Z33's Avatar
Steve-O Z33
If you have a laptop, you could probably load the maps onto it and use a cable to load them to your car. You would have to carry a laptop around to switch maps. Can anyone back this up or shoot it down?
Old Nov 18, 2010 | 10:45 AM
nathanwl2004's Avatar
nathanwl2004
wouldn't it be nice if uprev were to create a device that could be installed in the cabin of the car that would allow us with base models to switch between maps. it may even be more convenient for higher models to use than the current cruise control system.
wouldn't that be nice, uprev "hint hint"
Old Nov 18, 2010 | 12:05 PM
importdemon5's Avatar
importdemon5
Pretty sure that's what the cipher cable is for? Plugs into your laptop so you can switch between maps. Not sure though. Hopefully some vendors on here could chime in.
I was thinking bout building a laptop mount where the front part of the dash is on the passenger's side that comes out like a cop computer mount that you can pull towards you and do whatever you need to do then it folds back down and latch it down ha. I should make it. Just don't know how.
Check this out! Wonder if there is a way to extend it out so you can mount it under the dash?
http://chicagomounts.com/RAM-VB-168-SW1.htm
Old Nov 20, 2010 | 11:42 AM
0jiggy0's Avatar
0jiggy0
Laptop or netbook.
Old Nov 20, 2010 | 12:09 PM
NoQuestionZ's Avatar
NoQuestionZ
in for results
Old Nov 20, 2010 | 12:56 PM
Frostydc4's Avatar
Frostydc4
Z1 plenum spacer
Injen Intake
Stillen headers
Since you have a base you wont be able to switch maps per se. You would have to have 5 different ROMS created & if you want to change maps you would have to upload a new ROM to the ECU.
Old Nov 20, 2010 | 01:42 PM
RFortier1796's Avatar
RFortier1796
This is the one and only thing keeping me from finally settling on the UpRev. Having a base, loosing map switching on the fly is a bit of a turn off. However, I was thinking, and someone else would have to confirm this...what about a portable hard drive instead of a lap top. Get the tunes, load them to the hard drive, and then use a toggle switch or twist **** or some other super creative way to change the maps on the hard drive? It would beat having to lug my lap top around everywhere.
Or could you, with some creative hack and slashing, mate the Osiris cable to the end of an iPod cable? I mean...have it so one end plugs into wherever the Osiris cable does, the other into an iPod touch or iPhone or droid phone, and build an app to let you swap tunes?
I could be horribly wrong with all this though, and just be screwed out of having map switching on the fly.
Old Nov 20, 2010 | 01:59 PM
0jiggy0's Avatar
0jiggy0
Most other you need a computer to change maps. Whats the big deal?
Old Nov 20, 2010 | 02:19 PM
e30cabrio's Avatar
e30cabrio
My base runs amazingly after uprev went in.
Old Nov 20, 2010 | 11:06 PM
karletto66's Avatar
karletto66
In cars with CRUISE Control maps are stored in body pc and switched "real time" using some rom patch inside it (or similar tecnology)
In you don't have body pc with some free "eprom" to store maps and switch them, to change it you have to load one map at time directly using software and cable.
So only solution for the moment is to use pc...
IMHO !
Old Nov 21, 2010 | 07:22 AM
djamps's Avatar
djamps
You can install the cruize control wiring/switches, otherwise you'll just need to upload a different ROM each time you want to change map.
Old Nov 21, 2010 | 07:48 AM
e30cabrio's Avatar
e30cabrio
I am confused by the need to switch maps. My car was tuned to the maximum HP/TQ the motor could produce with no loss in MPG. The only reason I can think of would be because there was a loss that you only want to incur when you need max power.
I have 271/262 with major improvement throughout the rev range.
Old Nov 21, 2010 | 08:17 AM
karletto66's Avatar
karletto66
The ability to change the map is a "plus" but quite nice IMHO...
You can have for example (like in my case)
- 1 map "normal tuned", WELL TUNED but for "normal use" in normal street and highways. With 98 octanes (european) fuel.
- 1 map for "track days", with "extreme" tune, may be you can loose something in usability of car at low/medium range but with a few more hp in higher range and tuned for 100 octanes or more (always europe standard) fuel
- 1 map with "cut off" at let me say 3000rpm (if you give the car in some garage for works or similar and don't wont they use your car...)
Only examples !
If you have 1 only map usually you have the first of the 3, the most usable and good for "all days driving"
NOT a big problem anyway but with cruise control is simply...a little better !
Old Nov 21, 2010 | 08:48 AM
e30cabrio's Avatar
e30cabrio
Best we get on the left coast of the US at normal pumps is 92 octane, which sucks.
I guess if there was easily acquired higher octane it would make sense but seeing as I am not losing any MPG at the max level with the crummy 92 I am at I am happy.
Old Nov 21, 2010 | 09:12 AM
karletto66's Avatar
karletto66
European octanes is DIFFERENT from USA !
I suppose that your 92 is similar to our 95, your 95 to our 98-100...
In Italy normally fuel is 95 octanes so similar to your left coast...
I use 98-100 for my Z , in some pumps it's here...
If you use more higher octanes you can tune a map little more "aggressive" ar high rpm avoiding knock problems. NOT a big difference but as stated...al plus like "switch maps" is well accepted !
Old Nov 21, 2010 | 11:47 AM
seymore4's Avatar
seymore4
Professional
Uprev is in the process of developing both a module that plugs into the OBDII port to let you switch between maps, as well as an ap for phones that will let you change maps remotely, possibly tying it into the alarm so it automatically switches to the theft map when you arm the alarm, but as of now base owners are SOL.
Old Nov 21, 2010 | 06:41 PM
silents1ick
yeah it def seems like i m SOL
Old Nov 21, 2010 | 07:02 PM
06blueZ's Avatar
06blueZ
you could do a little experiment.. buy my 2006 cruise buttons, wire them in and see if they will control the maps, maybe the only difference on a base model is that the buttons are not there. The wiring is present for the steering wheel audio controls...
I know the ecu is different for models without cruise, but maybe osiris could still switch maps if there were buttons to send a signal?
