Which Engine Management to use?
Old Nov 28, 2003 | 07:03 PM
FLY BY Z's Avatar
FLY BY Z
Default Which Engine Management to use?
What would anyone who knows about engine management recommend for the following:
NA approach with some nitrous:
Stock bottom end with Tomei (268) cams
Lightly ported heads
Some form of intake manifold (Crawford or otherwise)
150 shot of nitrous
FI approach:
Built forged bottom end with 8.5:1 compression
lightly ported heads with Tomei (264) cams
DreamWorkes Supercharger (10-12 psi)
Which engine management system should I use for either of the two setups depending on which way I go. There is a better chance I will go with the first solution than the second but you never know...
I want to be able to rev high to take advantage of the cams, I want no top speed limiter, and I want to be able to adjust AF, timing, etc., through a laptop or otherwise to accomodate changes made in the future, weather, fuel type, etc. I want to have control.
I know there is Technosquare, Greddy EManage, AEM, and XEDE. Which should I use? Are there better alternatives?
Help!
Old Nov 28, 2003 | 07:52 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Will yo be tuning yourself or having someone do it? A tth end of the day, unless you have used programmable engine management yourself and don't mind a learning curve, use whatever it is your localtuners (who know their stuff) use. The actual choice of engine management is not really critical 9though admittedly, your choices are all over the board in terms of function, price and adjustability).
From a standalone perpective, AEM, Electromotive, Motec, Pectel, Haltech, etc are all remarkably similar, and all an be made to work very well...picking your tuner is the most critical choice.
Old Nov 28, 2003 | 08:10 PM
FLY BY Z's Avatar
FLY BY Z
Well, I think that after the initial tune I will be fine. I think that I would like the adjustability to be mine. I know the effects of each change I could make, I have just traditionally done it mechanically instead of electronically. So I guess what I am asking is what system would be the least expensive and easiest to use based on what I need. I don't need overkill or extras. I just want the car to run perfectly all the time (if possible). What is the simplest way to go with this setup and still maintain tunability? So far I think I like the XEDE but what about speed and rev limiters?
Old Nov 29, 2003 | 03:24 PM
moog's Avatar
moog
When I used to work at the local shop, we worked a lot w/ Bob Norwood. He knows how to install and tune Motec pretty well.
btw...I got a few pix of our meetup at Tinseltown from last weekend. I'll post em up in the TX section.
Old Nov 30, 2003 | 02:22 AM
mjedens's Avatar
mjedens
Default 1st Choice
Your 1st choice is what I'm trying to make work now! The A/F is a "*****"! Give me a couple more days and I'll have something narrowed down.
Old Nov 30, 2003 | 11:46 AM
Traffic's Avatar
Traffic
Standalone? AEM EMS. Make sure you find a really good tuner though.
Old Nov 30, 2003 | 05:55 PM
Z1 Performance
Former Sponsor
Xede may fit the bill nciely for you
E Manage may do it as well
if it were me, I';d wait a bit on it and see how thetest shake out - with something as important as engine management, no sense being a guinea pig unless you have to be
MAsSIVrOOM
Oct 20, 2023 10:50 AM
liqalu04
Jan 2, 2022 12:58 PM
Fixxxercask
Nov 9, 2015 11:10 AM
