More uprev questions.. license and reflash
Old Apr 26, 2011 | 09:22 AM
str8dum1's Avatar
str8dum1
another questions,
so once I have a license, anyone that has a cipher and the ROM editor program can reflash my ECU right?
Old Apr 26, 2011 | 12:30 PM
zerostyle's Avatar
zerostyle
I think they can use cipher on your car....but reflashing ecu's can only be done to one car cuz the license is married to one and only one ecu? Correct me if im wrong im tryna understand this as well...
Old Apr 26, 2011 | 12:39 PM
zerostyle's Avatar
zerostyle
Ok lets say for now all i want to do is bump my idle,clear codes,data...all i need is cipher cable 200??? Or i can find someone with the cable to do it?
And later on i plan on getting a vortech sc...if i wana get tuned with uprev i will need osiris? $300 license+tuning shop fees?
Old Apr 26, 2011 | 12:46 PM
k6750gsxr's Avatar
k6750gsxr
Originally Posted by str8dum1
another questions,
A person would have to have a tuner cable. That will give them the full access to the ecu for rom editing. For example i have a tuner cable. If I had your rom i could edit anything you wanted in it.
Problem is only the person who edited your map has your specific rom. I can not go in your car and plug my cable in and take your tune/rom. I would have to have your rom file that was edited in order to make modifications to your tune.
I hope this makes since.
Cipher can clear codes, bump idle, and timing on some cars. i have ran into issues before to where i could not change a cars timing or idle. If you do have a cable you can purchase the license for 300$ which will give you flashing capabilities for a tuner cable to modify you ecu for a tune.
Old Apr 26, 2011 | 12:57 PM
str8dum1's Avatar
str8dum1
my rom has never been edited, only the idle raised...
so you can just take a stock rom and edit that since I already have the license, correct?
Old Apr 26, 2011 | 01:08 PM
k6750gsxr's Avatar
k6750gsxr
thats correct. If i was to come to your house tomorrow. I could see what ecu number you have. Use the rom editor to change what you want, and flash it for you. ( this of course is if you have the rom file already for that ecu )
Old Apr 26, 2011 | 01:51 PM
zerostyle's Avatar
zerostyle
Yeah i read bout the certain ecus....is it a year thing, prodcution date thing? Or just hit and miss...
Old Apr 28, 2011 | 12:55 PM
rcdash's Avatar
rcdash
k6750gsxr contradicts Vince who claims that once a cable flashes an ECU it is married to that ECU. It is my understanding that you cannot go around flashing multiple people's ECU unless you are a pro tuner. Very confusing...
Old Apr 28, 2011 | 04:08 PM
djamps's Avatar
djamps
Pretty sure cable is married to the ECU in terms of rom editor. Each time you load a rom onto a 'new' ecu the license count on the cable goes down by one. Before each flash, rom editor checks the license on the ecu to make sure it's yours (so you don't lose another license)... if I'm wrong someone tell me. LOL
Old Oct 28, 2011 | 09:09 AM
midz350's Avatar
midz350
I have the GTM TT KIT ROM file in my ECU now, but I'm going back to stock now + exhaust and intakes.
Where can I find the "Back to Stock ROM file"?
Can I use somebody's else ROM (that has the same mods as me)?
Also will buy the Osiris Tuner version.
Old Oct 28, 2011 | 09:55 AM
str8dum1's Avatar
str8dum1
all i can say is that I used Raj's cipher cable to reflash my car with no issues.
I dont know where the license is stored, but its not in the cable.
I think you have to save the original rom from your ECU before you flashed it. It wouldnt make sense if you could use a generic rom cuz then there wouldnt need to be all those ecu variations.
Old Oct 28, 2011 | 10:46 AM
karletto66's Avatar
karletto66
Uprev send usually if you ask back-to-stock files.
You can put a file of someone else if it's for the EXACT same ECU number.
IMHO !
Old Oct 28, 2011 | 10:48 AM
karletto66's Avatar
karletto66
Uprev licenze is in the cable and after first write tranferred on ECU.
Usually you don't have tu dump your rom, Uprev have quite all in database.
So they use the right one to start tuning...
Old Oct 31, 2011 | 04:36 PM
rcdash's Avatar
rcdash
Just to clarify (before Rich gets me in trouble), Rich has paid for a flash already (from a pro tuner) so this should not violate the UpRev TOU. I guess if someone has paid for a reflash, they can be reflashed again without issue (i.e. the cable can verify that the ECU is licensed appropriately).
Old Oct 31, 2011 | 05:01 PM
str8dum1's Avatar
str8dum1
Raj, i dont think that there would be any other way to be able to reflash a non-licensed ECU.
Old Nov 1, 2011 | 06:07 AM
binder's Avatar
binder
so wait, i can take someone else's cable and then adjust my idle back down since i already have a license flashed?
interesting
Old Nov 1, 2011 | 06:19 AM
str8dum1's Avatar
str8dum1
as long as you have your rom
Old Nov 1, 2011 | 10:24 AM
  #38
rcdash's Avatar
rcdash
^ and as long as the cable has been flashed to an ECU at least once. This moves the license from the cable to the ECU. Then that cable can flash any licensed ECU. If you take a brand new cable and flash an ECU, I think you will overwrite the license on the ECU with the cable license and then you will never be able to flash a stock ECU again. The only time you can flash a stock ECU (using a non-pro tuner license) is with a brand new cable (that has one license on it).
Old Nov 6, 2011 | 05:23 AM
  #39
Vq35hr350z's Avatar
Vq35hr350z
Somebody! Help i just got berks hfc's today at my house, my current setup in my 2008 350z hr is skunk2 true dual exhaust and fujitgo dual intakes, i have not yet install the hfcs..... If i install my hfcs will i get a CEL? Or do i need a tune? If so what kind of tune ? Please PM me and tell me any info that would be helpful. I currently do not have a cel on exhaust and intakes... I do not want a cel, soo any help would be very thankful of you's! PM any info thank you! Also how much wheel power should i make on dynojet?
Old Nov 6, 2011 | 05:33 AM
  #40
0jiggy0's Avatar
0jiggy0
Everyone of your basic *** questions have been answered thousands of times. Using !!!! doesnt alert us to an emergency. You may get a CEL with HFC's. Some do, some dont. And yes you should get a tune with HFC's or TP's.
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
Twiztids4
Tuning
Sep 10, 2015 04:02 PM
