utech questions
Old Aug 26, 2011 | 01:41 PM
zach711f's Avatar
zach711f
Default utech questions
so i install my powerlab kit. how do i load the base map onto it. i put the turboxs cd in that came with the utech and when i try to open any folder it dosent work. i have no directions i called up turboxs and the guy said to check out their website for downloads. but its not for the powerlab kit and only the 550cc injectors or 750cc when i have 600cc..and i still dont know how to get thing thing to download onto it anyway???
Old Aug 26, 2011 | 03:27 PM
zach711f's Avatar
zach711f
basically i have everything installed and want to start the car. but i cant until i figure out how to get that 600cc injector base map on this utech..the directions show up as corrupt or someother error when i try to download or open them off cd or on the turboxs website
Old Aug 26, 2011 | 06:27 PM
djamps's Avatar
djamps
https://my350z.com/forum/tuning/5301...ec-manual.html
As it mentions in the thread, rename the file with .zip extension then you can open it.
Old Aug 26, 2011 | 07:09 PM
Ruthless18x's Avatar
Ruthless18x
Do you have the preloaded map from Intense or are you using a Utec not originally supplied with the kit?
Old Aug 26, 2011 | 07:44 PM
zach711f's Avatar
zach711f
I got the setup from intense but the directions say to load the 600cc map onto the utech but I see that no were on the cd. The cd that came with the kit is useless all the files are corrupt on it. I don't know if the utech is loaded with a map already and intense never answer my phone calls or mails.
Old Aug 27, 2011 | 08:34 AM
str8dum1's Avatar
str8dum1
just load the 550cc map. That will get the car running. then you must tune it. you'd have to do the same thing even if there was a "600cc" map
Old Aug 27, 2011 | 09:45 AM
zach711f's Avatar
zach711f
I know that I just want to be able to start the car get it on a trailor and bring it to the tuner for an osiris tune on the 1st. i just wanted to start the car and check for problems. but how do i even get the map onto the utech??
Old Aug 27, 2011 | 11:29 AM
djamps's Avatar
djamps
The car will start and get onto a trailer in bypass mode (map0) or with the UTEC completely disconnected and 100% stock ECU. Just don't go driving around town. Leave the loading of maps and tuning to your tuner, it's not easy if you don't know your way around hyperterminal and serial interfaces.
Old Aug 27, 2011 | 11:53 AM
zach711f's Avatar
zach711f
so what ur saying is i can start my car with 600cc injectors without ****ing anything up to get on a trailor? i have not installed utech yet i plan on selling this thing i dont really want to use it
Old Aug 27, 2011 | 11:55 AM
djamps's Avatar
djamps
It'll be pig rich but it'll run. Start it, get it on the trailer and shut it off.
Old Aug 27, 2011 | 01:20 PM
str8dum1's Avatar
str8dum1
mine was never pig rich any time i ran the stock injectors off the stock ecu. still idled at 14.x you just couldnt tip into the gas too fast.
Old Aug 27, 2011 | 01:22 PM
djamps's Avatar
djamps
He's got 600's. It will likely idle at 10-11 a/f
Old Aug 27, 2011 | 05:34 PM
zach711f's Avatar
zach711f
I just said screw it and started it up with 600cc's injectors and walbro installed. it idles anywhere from14-16.5 usually around 14. give it any gas and it goes to 10 so il just it on the trailor and shut it off
Old Aug 28, 2011 | 08:57 AM
djamps's Avatar
djamps
Good call str8!
Old Aug 28, 2011 | 10:08 AM
str8dum1's Avatar
str8dum1
ya i had 600s when i did that as well.. The stock ecu has alot of range. just have to ease on the gas real slow to keep AFRs normal
good luck with the final tune OP.
Old Aug 28, 2011 | 10:31 AM
zach711f's Avatar
zach711f
thanks man.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
