Boost Creep with Haltech?
Old Mar 9, 2012 | 11:59 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Default Boost Creep with Haltech?
On long boost runs up to 7k rpm, I get some boost creep from the set boost of 9.0 psi to about 10.5 psi. Below are my settings on my haltech. Any idea what to change to maintain steady boost?
Boost Setting 9.0
Proportional 75
Integral 25
Derivative 0
Control Start Pressure 7.0
Closed Loop Base Duty Cycle 25%
Old Mar 9, 2012 | 02:57 PM
djamps's Avatar
djamps
I see you have a JWT kit if it's the 530 this is probably normal
Old Mar 9, 2012 | 04:30 PM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
It is 530's, standard JWT kit. If that is normal, ugg. Any way to tune around it?
Old Mar 9, 2012 | 07:37 PM
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
Are you able to run spring (wastegate) pressure with the EBC off?
Old Mar 10, 2012 | 06:31 AM
str8dum1's Avatar
str8dum1
why not just tune for it. extra 1psi at the big end just extends your trq curve and makes your car faster.
Old Mar 10, 2012 | 06:52 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Where are you reading the 10.5? Is it in the haltech dash/log? Can you check what the output to the BC is?
If you are reading the 10.5 on an external gauge ( 2 map sensors, one to haltech, one to gauge) then there may be some differences between the two sensors/gauges.
The integral portion is used for removing error with time. Maybe increase it some?
Old Mar 10, 2012 | 07:51 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
External gauge, so I see what you are saying there.
I'll play around with the integral see if that makes a difference
Old Mar 10, 2012 | 07:52 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Oh, and as for tuning for it, 10.5 on a stock block is pushing it, and not something I really want to do.
Old Mar 10, 2012 | 08:38 AM
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Sounds like it's time for a short block build. LOL
Old Mar 10, 2012 | 09:54 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Thats why I did this:
https://my350z.com/forum/forced-indu...d-haltech.html
Old Mar 10, 2012 | 11:17 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Good idea, but no. Too much money. My G is fun enough as it is.
Old Mar 10, 2012 | 11:18 AM
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
Originally Posted by Cux350z
I'll read through that and check it out, thanks
Old Mar 10, 2012 | 07:39 PM
djamps's Avatar
djamps
You can't 'tune it out' but you can certainly tune around it. Just pull some timing above the boost level you aren't comforatble with. I have essentially the same turbos and have dozens of track passes peaking at 10-10.5 psi at times running a fairly aggressive tune.
apex locator
Jul 23, 2021 02:27 AM
