ignition timing at WOT for VQ35DE
Old Jun 18, 2012 | 08:09 PM
IP05G35's Avatar
IP05G35
Default ignition timing at WOT for VQ35DE
How many degrees of timing are you guys running at WOT when tuned? I datalogged my G35 at the track and it only sees 18-20 degrees at WOT when the engine is at it's optimum temp.
Old Jun 22, 2012 | 04:13 PM
nova15566's Avatar
nova15566
I am going to data log again but my last pull was 26-30deg from 2500-7k afr 13.5-12.5ish. I dd this tune and have failr decent power and tq from it... but it is pretty aggressive.
Old Jun 30, 2012 | 02:58 PM
binder's Avatar
binder
no idea.
You have to provide info about every aspect of the car. There is no set "timing" for any engine. Every car is different even with the same setups on them.
maybe post some info about the car so we might be able to at least get you in the ballpark. FI, NA, Nitrous, power level....
Old Jul 2, 2012 | 04:54 PM
djamps's Avatar
djamps
If you're N/A you should be seeing more than 18deg by redline. More like 30+. Keep in mind timing should increase with RPM so you need to tell us what RPM you're talking about.
Obadabot
Jun 18, 2023 11:31 PM
