ECU wont change into different maps???
Old Aug 8, 2012 | 11:10 AM
RGR350's Avatar
RGR350
Default ECU wont change into different maps???
Hey guys so I recently got an uprev tune from Z1 Motorsports and John over there did an awesome job. One problem though, I should have 4 different maps programmed in the ECU but I cant get it to switch into the different maps. I've searched quite extensively and came up with nothing......
There is nothing wrong with the cruise control and I've tried countless times to switch it using two methods: holding the cruise tab down and pressing cancel and vise versa. Any help would be great!!! Thanks
BTW i drive a 2008 350Z Grand Touring
Old Aug 8, 2012 | 11:28 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
You already paid Z1 for their service and support, give them a call
Old Aug 8, 2012 | 11:39 AM
RGR350's Avatar
RGR350
John and I have exchanged phone numbers to possibly work this out. and Ive already been to Z1 about this twice. Still no luck. John told me that my ECU might not be able to have different maps and I'm just not satisfied with that answer honestly. I want to do research and make 100% sure
Old Aug 8, 2012 | 12:47 PM
Suwaidi's Avatar
Suwaidi
ECU might not be able to have different maps? I wouldn't buy that either
How do you know your car isn't switching maps?
I know you've probably done this before a dozen times, but just to repeat the steps:
- Hold down accel/res (first button)
- While that's held down, press the cancel button x number of times
- Let go of accel/rest when you're done
Old Aug 8, 2012 | 01:03 PM
thisishk350's Avatar
thisishk350
If you have cruise control you can switch maps. search "G35 map switching" on youtube, there are plenty of tutorials. If it still won't work there's something else going on, contact Z1. You paid them good money for a service you shouldn't have to come on the forum and troubleshoot it yourself
Old Aug 8, 2012 | 01:36 PM
RGR350's Avatar
RGR350
Thanks gentlemen for the replies. Theres 2 ways I know its not changing maps. 1 I'm not getting the confirmation blinking light when I try to change maps, and 2 map 4 is valet mode. Car shouldn't go above 45 but when I get on it, it shoots past it like nothing
Just went out and tried every combination i can think of. Still no luck.
And trust me I wanted to make sure i wasn't doing anything wrong, which I'm sure I'm not. i text John today and if i don't hear back within a couple days I'm bringing a firey hell to their door step lol.
Old Aug 8, 2012 | 08:36 PM
Suwaidi's Avatar
Suwaidi
1) I don't get a confirming blinking light when I change maps =/
2) Have you tried all of the maps? Personally, I have valet set at 3.
Old Aug 9, 2012 | 04:30 PM
RGR350's Avatar
RGR350
So I went for a drive today and tried all maps 1 through 5 (even though I only have 4) and.......... still nothing :/
Looks like I'm going back to Z1 or something..... Feeling pretty lost at this point lol
Old Aug 9, 2012 | 06:38 PM
thisishk350
Are you absolutely sure they flashed an Osiris license onto your ecu?? I only ask because I've heard stories before... guys went to a shop to get tuned... the shop forgot to flash the ecu or some ****... If you have access to an uprev cable (any cable) plug it in and verify that it registers as an uprev flashed ecu
Old Aug 9, 2012 | 10:42 PM
Waiz's Avatar
Waiz
Moved to the correct subforum
Old Aug 11, 2012 | 03:51 PM
djamps's Avatar
djamps
If your cruise control works (buttons, lights and all) and you're POSITIVE you're 'doing it right' then you most likely DO NOT have an Osiris reflash on your ECU. Just sayin...
Old Aug 12, 2012 | 07:25 AM
RGR350's Avatar
RGR350
Thanks guys for all the help. Looks like I'm going back to Z1 again
Old Aug 13, 2012 | 07:02 AM
karletto66's Avatar
karletto66
When you change map with cruise control the light HAS to blink so manu times as map activated.
1 time for map1, 2 time for map2 and so on...
Seems no flash to ECU...
2ndchanceZ
Oct 26, 2015 08:03 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
