Is UpRev MAF GT necessary boosted w/haltech?
Old Aug 18, 2013 | 03:46 PM
SurraTT's Avatar
SurraTT
Originally Posted by Cux350z
Just worried about the idle.
I know the haltech has a fake output, guess that would need to be tuned.
Did you wire the gm sensor into the OEM wiring?
the stock timing is 15 deg at idle. shouldn't be much of a issue.
yeah you find out what 2 MAF wires are actually IAT and wire sensor into those
Old Aug 18, 2013 | 03:52 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
simple enough. You sell the mating pigtail for the maf so i dont have to cut and splice it?
Thanks for the quick replies! You must have notifications set up...
Old Aug 19, 2013 | 03:38 PM
SurraTT's Avatar
SurraTT
haha ya email notif.
i don't have the connector that would plug into the maf. Ive got tons of connectors though!
Old Aug 19, 2013 | 03:45 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Looking at the gm sensors, 1 chart says the numbers match closely but when i go to the vednors the numbers (resitance at said temp) is off.
Old Aug 19, 2013 | 03:48 PM
SurraTT's Avatar
SurraTT
what now?
in the haltech setup you would put in the value of the new temp sensor.
for GM the setting is already there you just hit load and go through all the pre installed sensor settings map sensors temp sensors maf sensors all kinda sensors in there.
Old Aug 19, 2013 | 04:05 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Oh, was planning on installing into the OEM wires and replacing the oem Thermistor with one with the same values.
Dont have my haltech software in front of me on work laptop so not sure about setting the params. I set the params for boost, widebands so i am familiar with that aspect.
Old Aug 25, 2013 | 07:09 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Code:
GM		Source V:	5	Divider Ohm:	1012
Celcius	Farenheit	OHMs	(+/- Ohms)	Low Ohms	High Ohms	Vthermistor	Vinput
-40	-40	99326	10.46	88936.5004	109715.4996	4.949570452	0.050429548
-35	-31	71332	10	64198.8	78465.2	4.930056397	0.069943603
-30	-22	51791	9.55	46844.9595	56737.0405	4.904172111	0.095827889
-25	-13	37994	9.11	34532.7466	41455.2534	4.870276368	0.129723632
-20	-4	28146	8.67	25705.7418	30586.2582	4.82646272	0.17353728
-15	5	21044	8.25	19307.87	22780.13	4.770583968	0.229416032
-10	14	15873	7.83	14630.1441	17115.8559	4.700325733	0.299674267
-5	23	12073	7.42	11177.1834	12968.8166	4.613297669	0.386702331
0	32	9256	7.02	8606.2288	9905.7712	4.507206856	0.492793144
5	41	7153	6.72	6672.3184	7633.6816	4.38028169	0.61971831
10	50	5572	6.43	5213.7204	5930.2796	4.231470231	0.768529769
15	59	4373	6.14	4104.4978	4641.5022	4.060352832	0.939647168
20	68	3457	5.85	3254.7655	3659.2345	3.86775565	1.13224435
25	77	2752	5.56	2598.9888	2905.0112	3.655685441	1.344314559
30	86	2205	5.28	2088.576	2321.424	3.427105999	1.572894001
35	95	1778	5	1689.1	1866.9	3.186379928	1.813620072
40	104	1443	4.72	1374.8904	1511.1096	2.938900204	2.061099796
45	113	1177	4.45	1124.6235	1229.3765	2.688442211	2.311557789
50	122	965	4.18	924.663	1005.337	2.440566515	2.559433485
55	131	796	3.94	764.6376	827.3624	2.201327434	2.798672566
60	140	660	3.71	635.514	684.486	1.973684211	3.026315789
65	149	551	3.47	531.8803	570.1197	1.762635956	3.237364044
70	158	462	3.24	447.0312	476.9688	1.567164179	3.432835821
75	167	389	3.01	377.2911	400.7089	1.388294076	3.611705924
80	176	329	2.79	319.8209	338.1791	1.226696495	3.773303505
85	185	279	2.57	271.8297	286.1703	1.080557707	3.919442293
90	194	238.1	2.35	232.50465	243.69535	0.952323814	4.047676186
95	203	203.9	2.13	199.55693	208.24307	0.838473559	4.161526441
100	212	175.3	2	171.794	178.806	0.738229597	4.261770403
105	221	151.3	2.24	147.91088	154.68912	0.650305166	4.349694834
110	230	131	2.45	127.7905	134.2095	0.573053368	4.426946632
115	239	113.9	2.63	110.90443	116.89557	0.505817568	4.494182432
120	248	99.4	2.79	96.62674	102.17326	0.447183732	4.552816268
125	257	87	2.92	84.4596	89.5404	0.395814377	4.604185623
130	266	76.4	3.03	74.08508	78.71492	0.350973907	4.649026093
135	275	67.3	3.11	65.20697	69.39303	0.311776151	4.688223849
140	284	59.4	3.18	57.51108	61.28892	0.277207392	4.722792608
145	293	52.6	3.22	50.90628	54.29372	0.247041142	4.752958858
150	302	46.7	3.24	45.18692	48.21308	0.220553509	4.779446491
what i came up with for the sensor
Old Aug 26, 2013 | 12:10 PM
SurraTT's Avatar
SurraTT
[IMG][/IMG]
GM air temp sensor
Old Aug 26, 2013 | 01:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
that graph is very close to my table. I still used 16pts for a very smooth curve.
Old Aug 30, 2013 | 03:02 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
my curve
350Z_Al
Oct 29, 2020 07:44 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
