uprev base tune for vortech.
Old Feb 20, 2015 | 07:03 PM
chase z's Avatar
chase z
Default uprev base tune for vortech.
iam buying a V-2 t-trim vortech tuner kit/ uprev tuner/DeatschWerks 600cc Injectors and a Walbro 255lph fuel pump.
is there any way to get a base tune so i can drive it to get it professional tuned?
thanks
chase
Old Feb 20, 2015 | 08:27 PM
Calinismo350z's Avatar
Calinismo350z
how far is your tuner?
I drove mine for 2 hours whithout an issue.
(same scenario)
you have 2 options:
either stay under 3k rpms so you don't hit boost or take off the cog belt and install it once you get there.
Old Feb 20, 2015 | 10:59 PM
jdm-v35's Avatar
jdm-v35
if you dont have a tuner nearby, and you have the tuner version of osiris you will need to self tune it to dial in fuel enough that its drivable since you are upgrading injectors.
Old Feb 21, 2015 | 06:36 AM
chase z's Avatar
chase z
It not hard to scale for the injectors or is it ?
Old Feb 21, 2015 | 06:37 AM
chase z's Avatar
chase z
(same scenario)
you have 2 options:
I haven't decided what tuner to use yet
Thanks for the info!!
Old Feb 21, 2015 | 11:02 AM
seymore4's Avatar
seymore4
Professional
Lawrence at Intec Racing in Kent has the most experience with forced induction on VQ's in the area, I would give them a call and talk to him
Old Feb 21, 2015 | 11:04 AM
chase z's Avatar
chase z
i all so had another question.
when u all installed a wide-band with your uprev did u disable one of your o2 sensor in the cats and replace one of them with the wide-band censor or did u get a new o2 sensor bung wielded in ? and i have stock cats and a tomei titanium exhaust.
Old Feb 21, 2015 | 11:15 AM
seymore4's Avatar
seymore4
Professional
I've seen it done both ways. Personally I would get test pipes with an additional bung and do it that way
Old Feb 21, 2015 | 12:39 PM
chase z's Avatar
chase z
thanks. i will email them to get the ball rolling
iam ordering all the parts this week and installing them over the next long weekend.
Old May 6, 2015 | 07:02 PM
usingthejohn's Avatar
usingthejohn
(same scenario)
you have 2 options:
Sorry for bumping an old thread. I am also in the same boat as the OP, and am concerned about what negative effects I'll have if I baby the car to my tuner? On stock ecu, I have an upgraded MAF, DW 600cc injectors, test pipes and a v2 vortech
Old May 7, 2015 | 01:36 AM
wannabuy350z's Avatar
wannabuy350z
if you changed your MAF i dont thing the car will be drivable at all unless you create a base map for your self
Old May 7, 2015 | 03:56 AM
jdm-v35's Avatar
jdm-v35
Different MAF and larger injectors, you'll be lucky if you can the car to start let alone crawl to a tuner without some type of base tune.
350z82
Oct 1, 2015 06:25 PM
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
