New cams, in need of a base tune
Old Mar 11, 2015 | 12:46 PM
thekyledeg's Avatar
thekyledeg
Default New cams, in need of a base tune
just looking for a decent safe/base tune for my new setup to run until i get to the dyno (hour drive) I made a DIY cam install thread by the way if anyones interested in looking its posted up.
Setup is:
HKS Dual
Ebay Headers (they were free, go read my build thread before you flame, i have a set of Dc's waiting if these break)
Test Pipes
Tomei 272/11.3 in/ex
JWT Springs
JWT POP-Charger
1/2" Spacer
Please bump redline to 7200!
Old Mar 12, 2015 | 08:53 AM
iideadeyeii's Avatar
iideadeyeii
Helps to know what you're using to tune.
Old Mar 12, 2015 | 02:00 PM
thekyledeg's Avatar
thekyledeg
my bad, Using uprev
Old Mar 12, 2015 | 04:11 PM
2bad240's Avatar
2bad240
Originally Posted by thekyledeg
my bad, Using uprev
Email your tune to 2bad240@gmail.com
Old Mar 13, 2015 | 04:18 AM
thekyledeg's Avatar
thekyledeg
hey, problem is i dont have a tune at all, uprev sent me an empty ROM file so i try to flash my ECU and theres nothing to flash it with. another member sentme a ROM file to try but it said "this rom is incompatable with this ecu type" im guessing it was for a different gen ecu as i have a gen one ecu
Old Mar 16, 2015 | 09:46 AM
jdm-v35's Avatar
jdm-v35
did you look on uprevs site under support on their "rom matrix" pdf? it will show you what rom you need based on ECU. you may need to remove the ecu to find what model it is exactly. Then uprev will send you the compatible ROM file to flash (with oem parameters). You will need to make changes to that file. I don't understand how they would send you an empty ROM file though.
350z82
Oct 1, 2015 06:25 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
