Will stock Uprev map pass inspection?
Old May 8, 2015 | 05:14 AM
rich2342's Avatar
rich2342
Default Will stock Uprev map pass inspection?
Long story short, failed state inspection, removing Art pipes for stock. If I switch to stock uprev map, is the ROM still considered flashed, I.e. is it a different serial number vs. stock? Massachusetts now detects flashed roms and flags cars which happened last year.
I can remove the tune all together if need be, but is there a way I can tell if I send someone my maps?
Thanks,
Rich2342@yahoo.com for quick response
Old May 8, 2015 | 05:21 AM
travlee's Avatar
travlee
Master
i would buy a stock ecu, throw it in when time for inspection
Old May 8, 2015 | 07:52 AM
rich2342's Avatar
rich2342
Well, I just flashed it back to stock. Took a few mins. Just a pain in the butt to swap out the cats. Anyone know how long before it will throw a code Untuned with ART pipes?
Would it pass with Art pipes and exhaust no tune?
Old May 8, 2015 | 08:09 AM
Junkster's Avatar
Junkster
^i know here in cali you will not pass without cats. Most people dont pass even with HFC's
Old May 8, 2015 | 11:10 AM
rich2342's Avatar
rich2342
Yeah, It will definately throw a catalyst monitor code, but I think it requires at least two codes for failure in MA.
Old Oct 15, 2015 | 08:05 PM
l.sanchez's Avatar
l.sanchez
I have motordyne tdx v2 aem cai and hfcs and i just passed smog, the stock tune should get you to pass aslong as all the original settings remain the same like timing
Old Mar 4, 2016 | 01:13 PM
NissanZcrazy's Avatar
NissanZcrazy
What did you end up doing?
How does your local emissions testing work? Does it hook up to the OBD2 Port? or is it run on a dyno at 2500 rpm and idle?
I am going through a similar thing with my Z also.
Old Mar 4, 2016 | 01:45 PM
rich2342's Avatar
rich2342
I returned to stock rom and swapped to oem cats. Rinse repeat each year since failing
Old Mar 4, 2016 | 01:50 PM
rich2342's Avatar
rich2342
Testing is done usually by visual and obd II port. Once it is connected all of prior years info comes up. So in my case I passed two years with HFC's and the readiness monitors were bypassed. On year three I failed.
I was told by the state inspection center that any time a rom is flashed the serial number changes from stock. That is how they detect tampering, also you can have no more than 2 or 3 readiness monitors unsupported or N/A in Massachusetts.
Old Mar 5, 2016 | 03:26 PM
terrasmak's Avatar
What year is your car ?
Old Mar 5, 2016 | 05:22 PM
rich2342's Avatar
rich2342
Not sure who you are asking, mine is 03.
Old Apr 6, 2016 | 11:06 AM
rcdash's Avatar
rcdash
You can pass with a UPREV tune so long as the DTCs associated with OBD readiness have not been disabled...
Old Apr 6, 2016 | 04:50 PM
rich2342's Avatar
rich2342
They were bypassed.
