Haltech Red Box Question
Old Jun 1, 2016 | 01:57 PM
Conway_160's Avatar
Conway_160
Default Haltech Red Box Question
So, I have a new to Redbox but I need some help since I haven't heard back from Haltech yet.
1st Problem, I cant see my A/F ratios my stock widebands. W/ Uprev I could see them can you just not see them with Haltech? Do I need to wire wide bands directly into my haltech if so what wires I don't see them in the manual.
2nd Problem, I don't have a VE table when I set it up to tune Via VE. The internal MAP sensor is used as the Fuel Load Indicator. Am I dumb? All I see is the fuel base map. Is that what I'm supposed to use to correct my A/F Ratio? If so am I really tuning via VE?
3rd Problem not really realated to haltech but, for those who have installed BC stage 2 cams. Do you hear or feel lope when you let your car idle? I notice mine a decent amount I'm thinking it may be something messed up internally (Bent valves )
Old Jun 1, 2016 | 05:57 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
1. are you on the original harness that shipped with? reason i ask is because the redbox shipped with a harness that was hardwired to the oem o2 pins in the oem ECU connector. Well...not all 350z have the luxury of wideband o2 from the factory. The harness with the silver box had additional auxillary pins so that oem or aftermarket widebands could be installed. Those pins go to same pins on the haltech and then you calibrate it. Also i believe you have to enable them in the software
2. Base fuel table is your VE table
3. My BC2 dont feel or sound too lopey but then again i set my idle to 1k
Old Jun 1, 2016 | 06:18 PM
Conway_160's Avatar
Conway_160
I have the redbox, thats hardwired to oem sensors. Mine has factory widebands I've verified this. Ill have to do some more looking into the software then.
Thanks man i was thinking it would be a percent table.
Does it shake your car? My car kind of shakes at 700-800 rpms i was thinking bent valaves but i dont hear anything.
Old Jun 2, 2016 | 01:15 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
nothing bad here and im on solid motor mounts.
it is like pct *100
Old Jun 2, 2016 | 02:03 PM
Conway_160's Avatar
Conway_160
Well i was just told that i need a wideband controller to get my haltech to read A/F ratio's... since the redbox doesy talk to the stock ecu it cant get any values from it i should have stuck with up-rev.....
Old Jun 3, 2016 | 03:43 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
I had to use a controller with my silver box because my car is an 03.
Wonder why the red box came wired to the OEM widebands but couldn't use them? sounds like a goof on haltechs part if so.
The oem ecu is the controller for the heater circuit/supply voltage for the oem sensors...the haltech just needs to take the feedback voltage and convert to afr/lamda.
The haltech intercepts most of the signals by way of the patch harness. Some of the signals are straight pass through.
Old Jun 3, 2016 | 03:56 AM
Conway_160's Avatar
Conway_160
If ihave to spend another 500 I'm going to be pissed.
Old Jun 3, 2016 | 05:53 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
fi may not be for you then
Old Jun 3, 2016 | 01:32 PM
Conway_160's Avatar
Conway_160
At this rate this car may not be for me. But i deff need a wide band can device. Now to figure 1 channel or two.
Old Jun 3, 2016 | 03:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
2 channel, doesnt have to be CAN. I do not run a CAN version.
Old Jun 3, 2016 | 04:38 PM
Conway_160's Avatar
Conway_160
Can i use any? What should i get?
Old Jun 4, 2016 | 03:53 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
http://www.ebay.com/itm/Innovate-DLG...1VeFmo&vxp=mtr
or you might recognize this as the old haltech dual widebands (no gauge on this one and cost more)
http://www.ebay.com/itm/Daytona-Sens...9UrXx8&vxp=mtr
Yeah all you need is a 0-5v signal and then you can map the points in the haltech for each end.
Old Jun 4, 2016 | 06:02 AM
Conway_160's Avatar
Conway_160
Thanks man! Ill be getting the innovative one.
Old Jun 4, 2016 | 05:35 PM
Conway_160's Avatar
Conway_160
Figured out the miss/shaking of the car....didnt hook up #1 cylinder after inspecting the spark plug.
Now i need to get this damn skave cylinder to bleed...
Old Jun 5, 2016 | 09:12 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
you need someone to trace back the 4th plug
silver harness
red harness
Old Jun 5, 2016 | 01:46 PM
Conway_160's Avatar
Conway_160
Well fml!
nomyth46
Jun 9, 2016 07:07 AM
turboed350z
Jun 3, 2016 05:54 PM
tcode
Tuning
May 26, 2016 11:27 PM
350zaddict
May 22, 2016 03:20 PM
JCat
Apr 8, 2016 08:16 AM
