Need Guidance
Old Dec 19, 2017 | 09:19 PM
Sunset350ZR's Avatar
Sunset350ZR
Default Need Guidance
I have learned through research here that the 05 Z has wise band oxygen sensor. Finally this summer I will be getting the car tuned. My question are a few. Will an aftermarket wide band be an upgrade and provide better tuning. Second what is a good wide band sensor if I need one, and do I need to get a WB gauge if all I really want is car to run as good as the tune will allow. I would like the interior to stay as stock looking as possible.
Thanks for any help.
Old Dec 20, 2017 | 12:24 PM
Conway_160's Avatar
Conway_160
You can just use the stock ones to get it tuned it on. Usually just want a wide band sensor if you're F/I so you can make sure everything is ok. But you can just get a Bluetooth obd2 adapter and watch your afr's on your phone.
Old Dec 21, 2017 | 05:33 AM
seymore4's Avatar
seymore4
Professional
You do not need an aftermarket wideband.
andypandy
Aug 7, 2007 04:56 PM
viper54
Jul 24, 2006 04:00 PM
vitaminZ
Apr 9, 2004 07:06 AM
