Idle lean
Old Feb 14, 2022 | 08:34 PM
Silver_Z's Avatar
Silver_Z
Smile Idle lean
hello everyone
I have 03 350z with single turbo setup. (turbonetics)
255LPH walbro stock fuel rails
GTR Injectors
GT30 TURBO
Plenum spacer
Uprev tuning
Problem is : Car Drivers perfect on high revs, but on IDLE after 2-3 min standing afr shows 14.7 and then suddenly it goes lean. 15.0-15.5-16. Code P0300 Random missfires and burcks from exhaust .
Upstream O2 sensors correct all time 100% 105% 110% 120% ..
New sparks, coils perfect, MAF ok, no Air leaks checked with smoke.. I don't know what to do..
Old Feb 15, 2022 | 04:59 AM
iideadeyeii's Avatar
iideadeyeii
Does your tune have a cold compensation where it increases fuel before the car warms up?
Old Feb 15, 2022 | 09:19 AM
Silver_Z's Avatar
Silver_Z
it happens when cold when warm when hot after drive, as soon as car stopps and idles it rendom misfires and leans
Old Feb 15, 2022 | 11:52 AM
iideadeyeii
If you keep the a/c on does this problem still happen? What's idle RPM?
Old Feb 15, 2022 | 07:01 PM
Silver_Z's Avatar
Silver_Z
ill try...
RPM under 1000 . 700-800 i think
above 12000 its getting ok as i giving rev, but under its leaning
Old Feb 20, 2022 | 10:02 PM
Silver_Z's Avatar
Silver_Z
nothing still same...
still changed plags, all colis perfect injectors tested ok, no leaks,
leaning at IDLE and missfires
Old Feb 22, 2022 | 07:56 AM
RENFRO's Avatar
RENFRO
It's either tune or fuel related. Double check your injectors/get them flow tested and cleaned. To me it seems like one or two could be sticking at idle.
Old Feb 22, 2022 | 08:16 AM
Silver_Z's Avatar
Silver_Z
CHECKed ! they work
Old Feb 22, 2022 | 11:18 AM
RENFRO's Avatar
RENFRO
Originally Posted by Silver_Z
CHECKed ! they work
How exactly did you check? Did you send them off for a professional cleaning and flow testing service?
If not injectors you might have a fuel pump issue.
Old Feb 22, 2022 | 08:06 PM
Silver_Z's Avatar
Silver_Z
I changed my fuel pump and its bucket with stock fuel pump and stock bucket same happened ...
what about fuel injectors.. i removed them all switched car end its working non of them leaks or opens .. so now i want to install stock injectors and see whats going on..
Old Mar 11, 2022 | 12:54 AM
Silver_Z's Avatar
Silver_Z
any ides everything works fine camshaft sensors crank sensor all .. still leaning at idle and misfires..
Refusing
Jun 29, 2021 10:21 PM
rottingcat
Jul 8, 2018 07:25 PM
turtle1678
Apr 13, 2012 07:16 PM
