The "right" way to tune the Z
Old Aug 15, 2004 | 10:02 AM
NzZ's Avatar
NzZ
Default Well this is disappointing news...
I was hoping to invest in a modest FI setup...something to put the car around 280-300rwhp...but if the experts say internals...I'm just gonna drop the idea entirely...too much $ for a stingy bastard like myself.
On a side note, has anyone had problems w/the stillen kit? I haven't seen any cases...but I'm sure they're out there.
Old Aug 15, 2004 | 10:09 AM
PhoenixINX's Avatar
PhoenixINX
Originally posted by hfm
Of course, one can do the general NA bolt ons and should be safe from detonation but it becomes a $/hp issue and from watching Jeff@Performance's everything including the kitchen sink Z being built NA, I think the ceiling is about 270 rwhp.
If that's the case... mind explaining how Mike (mjedens) has already passed the 300rwhp NA???
Old Aug 15, 2004 | 11:13 AM
Speedracer's Avatar
Speedracer
What are his exact mods to get 300rwhp NA?
Old Aug 15, 2004 | 12:56 PM
Z BOY's Avatar
Z BOY
So what do you obviously knowledgeable tuners have to say about n20 and its effect on our engine?
Old Aug 16, 2004 | 03:53 AM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Default Re: I like your choice of pistons.....
Originally posted by Speedracer
No need to go to an 8 range compression ratio. 9 will still give you a decent off-boost throttle response. I would go with 10 psi boost with 9.0:1 CR given your piston/rod configuration.
Hmm...did I mentioned 8'something:1? I actually went with 9.0:1 on my car, and with the group-buy, the members could chose the compression ratio of your choice. At the end, the memebers chose a wide selection of CR's from 8.5:1 to 9.5:1
10psi with 9.0:1 will give you, roughly, 400-420whp....very safely with forged internals.
Old Aug 16, 2004 | 03:54 AM
Sharif@Forged
Forged Performance
really? was this on a dynojet? dyno charts please.
Old Aug 16, 2004 | 05:33 AM
Daniel G's Avatar
Daniel G
wow, how depressing. I guess my G35 will remain normally aspirated. Hell, I don't even have bolt on's on my G, unless you count the Z-tube. Everything else is stock. Reason being, I was going to do the "all or nothing approach"..meaning forced induction with maybe exhaust. I guess it'll stay stock. I'll just use my other car for high HP fun. That sucks, I wanted a 350 rwhp G35. Oh well.
Old Aug 16, 2004 | 07:58 AM
Z BOY's Avatar
Z BOY
Default Re: Re: I like your choice of pistons.....
So how much are forged internals?
Old Aug 16, 2004 | 10:08 AM
Speedracer's Avatar
Speedracer
Default Re: Re: Re: I like your choice of pistons.....
You can get a decent set of forged pistons/rods for about $2000 at the cheapest. Can go up from there. Up to $4-5000 on the high end. On the average, I would say about $5000 for parts and labor. Of course, while the engine is out, it would make good sense to use the opportunity to install other stuff....cams, header, flywheel, clutch,etc. It would substantially reduce the labor costs of these other installs, although your initial outlay of cash will be more. For instance, clutch/flywheel install can be an 8 hour job if done seperately, but will take 30 minutes with the engine already out.
Old Aug 16, 2004 | 10:14 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
The car is not maxed from the factory at all...people have just started the development work on it to see what it takes to make these motors sing, NA and FI. 300 hp NA is achievable...yes at a cost, but it is achievable on stock internals.
As for low end torque vs high rpm power, there is not really much that can be done about this...its the simple nature of the motor that's included. Put some cams in with little lift and loads of duration and watch that figure change drastically. Given the confines of the stock motor though, as well as gearing, this won't be a low end monster......but it's not intended to be either IMHO. My goals wth my own car were simple - take the stock powerband, which is totally usable for everyday, and exploit it.
Are forged internals the answer? For some, they are the only answer..for others, they are a complete and utter waste of funds IMHO. Nissan has blessed us with a good platofrm that responds reasonably well to even bolt on mods in NA form, and amazingly in FI guise. Is it expensive to make the power NA? Yep. Is it more expensive to do it via some form of forced induction....very often, the answer is yes again. However, they key to this car, or any other car is the tuning, not what turbo kit you pick, or what headers you select.
In terms of the M3, I am sorry but they are simply not fast cars at all.....much like ours are not fast from the factory. Quick - yes very. Beatlable? Absolutely
GQ - 3 cars is a very significant difference.....don't sell yourself short! As for not handling boost, I would 100% disagree....it is all about who does the tuning. now, I'd love to say I agree and sell loads and loads of forged internal packages to people, but is simply not the case. The motor is totally able to cope with a modest boost, provided the tuning is done skillfully However all too often people on this site, and many many others "think" they understand what they are doing, without actually knowing what they are doing....and that tends to lead to at best a car with a boat loads of mods that runs no better than stock or at worst, a broken motor in no time flat.
Old Aug 16, 2004 | 10:28 AM
PoWeRtRiP's Avatar
PoWeRtRiP
actually this car is very tuneable for an na engine. just being able to build up to and reliably support near 300whp on stock fuel, internals, and drivetrain is a remarkable feat for a 3.5l low revving motor.
there was a big contest last summer over who was gonna come out on top in na hp. several members have hit 280+ whp, and a few even got in teh 290-300 range. and only mjedens rebuilt his motor to get there.
this is a torquey motor not a high revving hp motor so try and focus on the area under the curve.
PoWeRtRiP's Avatar
PoWeRtRiP
Old Aug 16, 2004 | 10:32 AM
Z1 Performance
Former Sponsor
and mjedens didn't even really "do" anything special...he is still at stock CR, and only the heads received the real attention.....his setup is totally duplicatable (is that a word?) on an otherwise stock bottom end
Old Aug 16, 2004 | 10:47 AM
jrotaryb's Avatar
jrotaryb
Default Re: The "right" way to tune the Z
After waiting for my car for 4 months, and now owning it for another 4, I have spent many many many hours researching the best way to RELIABLY tune this car. It isn't easy...here's why:
The Z was designed on a certain budget. Within that budget, Nissan has really maximized the performance of this motor. Remember, they have already squeezed another 47hp from this engine since it's original introduction in the Maxima a few years back.
So, what's the big deal, you say? Throw in another $10k in mods, screw the budget, and you have more power, right?
Well, not quite. That's because within the constraints of their intended budget, Nissan has come close to maximizing what this engines internals can reliably tolerate. And...to go with much better internals, stock, would be well beyond the intended budget.
What all this boils down to is that to get serious power reliably in this car, an internal upgrade is really what is called for as the place to start. Sure, there is another 30hp to be gained from non-internal NA mods (this includes cams), but those mid-upper rpm gains come at the expense of low end torque to one degree or another. Good for the track, debatable for the street. The percentage of failures with FI is also quite high on stock internals.
Quality costs. Period. There is a reason an M3 with 333hp costs $55k.....and that engine also runs on the ragged edge. My previous Audi S4 was able to handle 25psi of boost on stock internals....forged from the factory.
Did anyone get a good look at that sign on the front of Toretto's garage in "The Fast and the Furious"........
Fast + Good = Not cheap
Fast + Cheap = Not good
Good + Cheap = Not Fast
Words to take seriously.
Where do I begin...
Well, your most obvious venture into the land of moronville lies in the fact that you reference "The Fast and The Furious" in a post about the "right" way to tune a Z. Dude, it's a movie. This movie in particular shouldn't be used as an example to do ANYTHING the "right" way.
That aside, you really have no idea what you're talking about. My guess is that your past tuning experience is limited to an Autometer air/fuel light show gauge and an SAFC on an '94 civic
Any motor will withstand additional stress, even that of forced induction, based on the quality of the tuning it sees. An OEM 350Z motor is nowhere near the strength limit of it's internals...that is a truly ridiculous thought. You're telling me that the motor in a '92 non-vtec civic can withstand 5 psi but your '04 350Z just isn't strong enough?!? BS. The "budget" portion of the car as an effort to make it affordable, went into the interior/exterior quality of the car. Poor paint, cheap interior materials/plastics etc...were all sacraficed to make the car affordable but I can assure you that Nissan gave you a strong motor.
To sum up, you're just plain wrong. You don't have to throw $ at a project un-necessarily. You want all components in the car to work as a team which is totally dependant on how well it is tuned.
Old Aug 16, 2004 | 10:55 AM
bwzabodyn's Avatar
bwzabodyn
What exactly does mjedens have? what's the special thing that has him over 300 whp n/a? that's my goal - a 300 whp N/A daily driver - I just don't know how to get there...
Headers, Cams, and a reflash is next on the plate, but what else? Is the 350evo throttle body worth the trouble? What about porting/polishing the heads/lower intake? I'd like to hear people's advice on this subject, it's been dead for a while since the F/I craze has really consumed most of the Z/G crowd...
Old Aug 16, 2004 | 11:41 AM
jwkirkland's Avatar
jwkirkland
Originally posted by jreiter
When you say hardly louder than stock, do you mean just cruising on the freeway, or all the time? I'm looking for an exhaust right now, and I don't mind loud when I'm on the gas, but I do *not* want it loud or droning while I'm crusing on the freeway.
The Stillen exhaust may be what you are looking for...
Old Aug 16, 2004 | 12:23 PM
VandyZ's Avatar
VandyZ
big tomei cams, close to stock pistons (10.5:1), plenum, headers, test pipes, ECU, stillen exhaust. I think he is running under 300 right now, as his car has gone through several transformations. But I think that is what he was running when he hit 301 N/A on the Dyno (dynojet).
Oh and like GQ it is my unprofessional opinion (because I am not one) that this motor is not safe to boost at the levels people are trying. I dont think some of these Mickey mouse tuning solutions will hold this engine together. Now it can be done correctly, but it will take more effort than buying a s/c or turbo kit and using the included tuning solutions. Money will have to be spent to make it work right. I foresee many popped motors in the near future as the miles increase on these F/I cars.
Old Aug 16, 2004 | 12:43 PM
  #38
hfm's Avatar
hfm
The dyno. We all know dynos are different from one location to another and are different between type of dyno machine. There are some machines that produce numbers that are far higher than they should be. What matters is the difference between stock and mods.
Many of the So. Cal. group have obtained dynos from more than one location and from what I've seen, with max NA mods, the best output was about 270 rwhp. There were those two dynos done at Mossy with 310+ rwhp that we all discounted as being incorrect. From memory, I believe Richard did a redyno at another location and came in the 270 rwhp range as well.
If there were more Zs pulling 300+ rwhp with maxed out modifictions, I'd be more likely to believe it's possible. As it stands, I'm comfortable with my current understanding.
  #39
hfm's Avatar
hfm
Default duplicate post
Old Aug 16, 2004 | 01:33 PM
  #40
Speedracer's Avatar
Speedracer
Default Re: Re: The "right" way to tune the Z
[QUOTE]Originally posted by jrotaryb
[B]Where do I begin...
I won't get into a pissing match.
Over 20 years, I have owned and tuned a Mustang from 175 to 400hp. Two Honda Preludes including one with a Jackson Supercharger, An Audi S4 into which I invested $40,000 in tuning and Mods, and now my new Z. I have also helped in the tuning of a 700hp Vette and 800hp Viper. How's that for tuning experience?
