New AAM Spec Fuel System Upgrades for 350Z/G35
Old Jul 13, 2004 | 02:47 PM
Mike@Altered's Avatar
Mike@Altered
Default New AAM Spec Fuel System Upgrades for 350Z/G35
AAM SPEC FUEL SYSTEM UPGRADES for the 350Z/G35
!NEW PRODUCT RELEASE!
Altered Atmosphere is proud to release three new fuel system modifications for the 350Z/G35!
FUEL PRESSURE GAUGE/ISOLATOR MOUNTING BLOCK
Introductory Price through July 31: $79
For pressure gauges, gauge isolators, senders, or sensors
Many of our customers ask us for an easy solution when mounting fuel pressure gauges, fuel pressure gauge isolators, or fuel pressure sensors to the factory fuel system. We developed an adapter block with a 1/8” NPT tap (most fuel pressure gauges/isolators are 1/8” NPT) that bolts neatly onto the factory fuel line. Our 350Z fuel pressure adapter kit eliminates having to cut into the factory fuel line for a fuel source.
BILLET ALUMINUM RAILS
Introductory Price $499
Regular Price $599
New to the plate are our billet aluminum 350Z fuel rails. They are engineered to accept both factory and RC Engineering injectors. We’ve made several significant design updates over the factory rails to help ensure the injectors have plenty of fuel available to them. These rails can be used in a custom RETURN style system or can be purchased with our fuel adapters to mate to the factory fuel system (the factory fuel rail adapters are not currently available).
FULL RETURN STYLE SYSTEM
Introductory Price through July 31: $895
We are also offering a complete return solution for those who demand extreme fuel flow and adjustability. Our kit comes complete with the following:
• 2 AAM Spec Billet Aluminum Fuel Rails
• Stainless Steel Braided Return Line
• All the Necessary Fittings
• Installation Instructions
• Aeromotive 1:1 adjustable fuel pressure regulator
• Goodridge Braided Stainless Steel Fuel Lines with Red/Blue Fuel Fittings from the Factory Fuel Feed through the Return Line
All fuel lines come pre-assembled for a simple installation. This is one trick kit that all high horsepower 350Z’s should consider!
Please Contact Us Through Phone or Email!
301.330.8835
sales@alteredatmosphere.com
Old Jul 13, 2004 | 03:12 PM
Unison8's Avatar
Unison8
ibtl, unless of course your paid sponsor.
Old Jul 13, 2004 | 03:40 PM
Juztin's Avatar
Juztin
oooooooo
Old Jul 13, 2004 | 04:57 PM
KrazY-2K's Avatar
KrazY-2K
Nice!
Just a friendly word of warning though; might wanna become a sponsor with this forum or Mike won't be too happy
Old Jul 13, 2004 | 06:55 PM
JeffesonM's Avatar
JeffesonM
nice setup! might want to post a link to this in the F/I forum.
Old Jul 13, 2004 | 07:56 PM
luanda's Avatar
luanda
Default Fuel Pump??
Is there an upgraded Fuel pump with the complete solution? Do you Mod the stock one? Do you use a PiggyBack?
Thanks
Old Jul 13, 2004 | 09:57 PM
350Now's Avatar
350Now
ohhh very nice. What's the price after the introductory period?
Old Jul 13, 2004 | 10:01 PM
MY350Z.COM's Avatar
They are a sponsor.
Old Jul 13, 2004 | 10:28 PM
o snap its eric's Avatar
o snap its eric
what does it do?
Old Jul 14, 2004 | 11:31 AM
dynamic6er's Avatar
dynamic6er
Default Re: Fuel Pump??
Hi Everyone.
Thanks for your questions! I'm Dave Shiroma, the new Sales Manager at Altered.
Thanks
The FULL RETURN FUEL SYSTEM does not include an upgraded pump. We can provide the Walbro 255lph which is practically a direct drop in for the factory pump.
We are also looking into creating a new full tank assembly that will accept a larger pump. This will be available as an upgrade option to the existing kit.
The AAM SPEC system removes the factory regulator's control of fuel pressure and replaces the control with a vacuum/boost controlled unit from Aeromotive. This allows you to adjust the level of pressure depending on the amount of vacuum/boost you are running at that moment. With the Aeromotive unit you set the base pressure at idle (50-55psi for 350Z/G35's), the unit then adds one pound of fuel pressure for every pound of boost.
o snap its ericwhat does it do?
Our New Dual Fuel Rail System is a replacement and modification to the factory system. The factory system is a "returnless" style system, which offers minimal adjustment to the amount of fuel the engine can receive. Another negative aspect of the factory system is the factory fuel pressure regulator does not allow fuel pressure adjustments and is incapable of holding a constant fuel pressure with most aftermarket fuel pumps.
The benefits of our Duel Fuel Rail Kit are as follows:
-Adjust fuel pressure
-Adds fuel pressure under boost
-Each rail is fed individually for equalized fuel flow
-Larger internal diameter for improved flow
-Redesigned injector hood (internal portion of rail that the top of
injector receives fuel from) that offers much better clearance
and flow.
Hope that helps! Please feel free to call us, email, or post any questions.
Old Jul 14, 2004 | 02:13 PM
spazpilot's Avatar
spazpilot
Nice, but your price seems a little high considering aem will be releasing there fuel rails for half the price.
Old Jul 14, 2004 | 03:26 PM
12SecZ's Avatar
12SecZ
Sweet setup Mike!
I'm drooling.... The modifications are never ending I guess.
Old Aug 18, 2004 | 09:37 AM
Dr Bonz's Avatar
Dr Bonz
Charter Member #19
Mine is going in as I type this. I will keep you all posted with pics and a write up in about a week.
Old Oct 3, 2004 | 01:07 PM
HK$FairladyZ's Avatar
HK$FairladyZ
Aem has fuel rails coming out?
Old Nov 29, 2004 | 05:43 PM
booger's Avatar
booger
I just got your fuel return system , and Im putting in RC 550 injectors . Could you tell me what clips I need to install the injectors ? And where I can find them ? thx...Bill
Old Nov 30, 2004 | 04:15 PM
dynamic6er's Avatar
dynamic6er
You need the Denso Injector clips. You can get them from RC or give us a call and we can get a set for you. Thanks for your purchase!
Old Dec 1, 2004 | 05:26 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
Mike - check your PM's
EnjukuRacing
Sep 30, 2015 06:55 AM
