Early stages of HR/VHR intake manifold dyno testing.
Old Sep 12, 2007 | 05:53 PM
  #41
Hydrazine's Avatar
Hydrazine
MOTORDYNE-MY350Z SPONSOR
That would be possible if the assembly came up out of the hood...
Would that be acceptable to the masses?
Old Sep 13, 2007 | 12:31 AM
  #42
jimmyloose's Avatar
jimmyloose
Six of those pointing out of the hood... My head would explode into gummy bears. Mother Teresa would weep. God would come down and shake your hand. It would be a great day for Nissan fans everywhere.
Old Sep 13, 2007 | 09:12 AM
  #43
ZLadie2000's Avatar
ZLadie2000
YES
Old Sep 13, 2007 | 09:48 AM
  #44
NA&CH's Avatar
NA&CH
If you guys get ITBs nice and working I am getting an 07 HR...
Chris
Old Sep 13, 2007 | 05:10 PM
  #45
warmmilk's Avatar
warmmilk
they don't have to stick out of the hood, u can make them curved
Old Sep 19, 2007 | 04:14 AM
  #46
WalkerT's Avatar
WalkerT
Professional
Updates?
Old Sep 19, 2007 | 06:34 AM
  #47
Hydrazine's Avatar
Hydrazine
I was counting on being able to swap manifolds to do quick and easy exploratory testing, but Nissan threw a bucket of water on the party.
This will take time. Next step is to get both manifolds 3D scanned and digitized. Next step is to modify the design so they are interchangable. Next step is to build rapid prototypes. Next step is to test fixed geometry manifolds. Next step it to do analysis on the data. Next step is to design a variable geometry prototype based on the data. Next step... ughhh I can keep typing for two more pages.
As you can see, I have a lot of work to do and it won't come together any time soon.
But it will happen because it must!
Old Sep 19, 2007 | 08:21 AM
  #48
quidproquo's Avatar
quidproquo
Need a Tune!!!
OK... I can wait another week or two.
Honestly... Tony, thank you for your dedication and determination. It takes as long as it takes. We need products that are well thought out, thoroughly tested and perform as advertised in the real world. It's guys like you that make owning these cars more pleasurable!!!
Old Sep 19, 2007 | 10:34 AM
  #49
Peak350's Avatar
Peak350
Just out of curiosity. Are you trying to do a variable geometry manifold only for the HR, or is it something you would try to reverse engineer to work with the older cars.
My thoughts on this are (and the reason I am asking) that a variable geometry manifold will likely require an ECU retune, if not a piggyback capable of handling multiple systems (cam timing, ignition timing, manifold position, variable fuel maps based on the above 3). Sounds expensive and time consuming to develop, but also like a rewarding technology if done right.
Am I making too many assumptions and this is possible something that can use the factory ECU (maybe with a reflash?) and the manifold "change" point can be controlled by an RPM pickup or possible even the exhaust cam timing?
Old Sep 20, 2007 | 02:46 PM
  #50
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I can see it now....
an 05 350Z, with its sleek hood,
next to another 05 350Z, with the Stillen hood,
right next to an 07 350Z with the "HR bump" hood,
finally,
THE MOTORDYNE HOOD
Old Sep 27, 2007 | 06:54 AM
  #51
ZLadie2000's Avatar
ZLadie2000
any updates?
Old Sep 27, 2007 | 11:22 PM
  #52
hiz-n-herz's Avatar
hiz-n-herz
Yeah, come on Tony. It's been like a whole week
From the sound of it, I am guessing there'll be no news here for about 60-90 days at a minimum.
But we can dream!
What about that exhaust you were working on (Sorry.. threadjacking)
Old Oct 9, 2007 | 01:43 PM
  #53
FRLDYZPIMPN's Avatar
FRLDYZPIMPN
subscribing!
Old Oct 9, 2007 | 01:53 PM
  #54
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Any day now Tony...wheres the update?
Old Oct 9, 2007 | 03:13 PM
  #55
Hydrazine's Avatar
Hydrazine
This will be a while. I have to design prototypes from scratch and it won't be easy.
Old Oct 9, 2007 | 04:09 PM
  #56
Peak350's Avatar
Peak350
Come on, thats like a 3 hour job, snap to it
Obviously joking. I'm curious if you ever got any dynos comparing the two manifolds that you could post though (or if you have them are you wanting to keep it to yourself for R&D reasons).
Old Oct 9, 2007 | 06:28 PM
  #57
Hydrazine's Avatar
Hydrazine
No comparative testing yet. That's what will make it a lot more difficult.
Nissan didn't want anyone to do this.
Old Oct 9, 2007 | 06:32 PM
  #58
Seb-Specialty-Z's Avatar
Seb-Specialty-Z
Big 2nd
With the 07, I have found that Nissan really doesn't want us modding it much.
We are having some issues.....to say the least. We'll get through it working with JWT and others.
Old Oct 9, 2007 | 08:00 PM
  #59
warmmilk's Avatar
warmmilk
Originally Posted by Seb-Specialty-Z
Big 2nd
don't be a party pooper, we want details (in depth)
(u can start a new thread so that we don't end up hi jacking this one)
Old Oct 9, 2007 | 08:01 PM
  #60
Peak350's Avatar
Peak350
I know you said that the manifolds were just slightly off in bolt pattern. I don't know where the bolts that are off are (and since I haven't really seen the manifold off the car I can't make a good judgement) but is it something you could just bore the bolt holes out, use some washers or a backer plate against the head of the bolt, and get the manifold to work well enough for a few pulls?
Or are we talking the whole manifold has to be remanufactured because of this.
I'll make a fairly bold statement that I don't think the variable valve lift will prove to be benefitial. There are 2 or 3 very basic issues I have with it, one being forced induction (see Alpina ASA blown valvetronic engine requiring a throttle body to be added). The second being that it reduced airflow restriction by 2-3%, and gives that almost completely in gained hp, but also adds complexity to the valvetrain which adds chances for a future failure. the 3rd is that I'm not sure its going to be anything short of a tuning nightmare. I'll see if I'm proven wrong, but I would guess that the VQ35HR will prove to be MORE promising than the VQ37HRV (I think thats the code) as far as big power is concerned.
