My Stock 07 dyno/strip weekend(vids)
Old Mar 31, 2008 | 07:28 AM
07Z FoSho's Avatar
07Z FoSho
Originally Posted by 07Zroberts
Just curious but what rpm gave you the best launch? Im gonna run at the track here soon but want to learn a lil about rwd launch before i go. My subaru lanches at about 5000-5500 and is all go out of the hole but the z seems like itll be harder to me. any advice?
im not really sure what rpm i did, i was looking at the light and just listen to the engine. but if i were to guess i would say about 4000 with a light slip, maybe a bit lower.
your just going to have to go and get the feel for it man thats all i an really say, good luck though
Old Mar 31, 2008 | 07:31 AM
07Z FoSho's Avatar
07Z FoSho
Originally Posted by SpdFreak
Did you power shift?
by power shift do you mean clutchless shifting??? no, just normal shifting but very fast. off gas, clutch in, change gear, clutch out, on gas.....
Old Mar 31, 2008 | 07:33 AM
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by plumpzz
It doesnt make a difference, the dyno is corrected for it. 5th gear on the HR and i'm pretty should he wouldn't be able to redline it.
Actually it doesn't correct for what gear you run the car in. Only temp, alt, barro, etc.
5th gear is 1:1 and is the proper gear to dyno in, but it will hit the speed limiter at 160. So you will get better higher numbers in 5th but not get to see redline. Use 4th to see redline.
I did one in 4th and 5th, and you can see below the stock numbers:
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Originally Posted by WalkerT
yes it does make a difference. Do you next pulls in Fifth. I did and no limiter for me. It needs to be 1:1. Study up on it.
There is a speed limiter in 5th, it's at 160mph. See my dyno.
Old Mar 31, 2008 | 07:56 AM
Gooey's Avatar
Gooey
My 5th gear dynos reach redline
Old Mar 31, 2008 | 07:58 AM
Motormouth's Avatar
Motormouth
I just saw dynos posted last night that were done in 4th and 5th and it was a difference of 2hp or something minimal like that. really not important.
Motormouth's Avatar
Motormouth
let me guess, AAM flashed no top speed limiter??
Old Mar 31, 2008 | 05:40 PM
SpdFreak's Avatar
SpdFreak
Meant flat foot shifting, powershifting, WOT shifting.
Old Mar 31, 2008 | 07:01 PM
Peak350's Avatar
Peak350
Or 4.08 gears
