309hp & 257.1 ft. lbs. Intake, Test Pipes, Emanage Blue - Dyno Plots Inside (Dynapac
Old May 10, 2008 | 08:53 AM
  #121
New JerZ's Avatar
New JerZ
[img=http://img356.imageshack.us/img356/1125/1000414oi9.th.jpg]
Heres what we got with AEM intakes and Turbo XS exhaust... Test pipes in next week.
Old May 11, 2008 | 05:02 PM
  #122
New JerZ's Avatar
New JerZ
tuned with the wrong octane in the tank and no test pipes @ 292 whp... Updates comin next week.
Old May 12, 2008 | 05:40 AM
  #123
rkemp1's Avatar
rkemp1
Thats good for DD. Those numbers are usually a little lower than dynojets. Nice!
Old May 12, 2008 | 05:46 AM
  #124
New JerZ's Avatar
New JerZ
those are DD corrected numbers (DJ). DD was right at 260 WHP.
Old May 12, 2008 | 05:50 AM
  #125
rkemp1's Avatar
rkemp1
Oh ok, gotcha.
Old May 13, 2008 | 03:40 AM
  #126
Zedness's Avatar
Zedness
Hey although this is my first post...hello. I was curious are you guys using the Greddy harness for the E-manage. Just wanted to know if the N-13 harness listed on Greddy Website for the VQ35DE works with the VQ35HR, I want to use an e-manage ultimate but would like to know if it will work with the harness for the VQ35DE(the harness for both is the same). I live in Australia and all our stuff is JDM spec. Also I keep seeing you guys talking about 91/93 octane fuel? To the best of my knowledge the U.S pretty much rules the Western world, however our premium fuels are 95/98 octane. And yet your 350's post much higher whp's, I have an 07' and when she was stock she pulled 181.2kW atw (243whp) on 98 octane on a Dyno Dyanmics. Do we have different ways of rating fuel? because the japanese run 100 octane. To finish you guys run an awesome site, so cheers for making it easier for me to mess with my Z.
Old May 13, 2008 | 03:52 AM
  #127
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
afaik the ecu harnesses are different.
Yes, there are differences between octane ratings in the US vs the rest of the world (go figure lololol...we can't seem to use the metric system either!)
"Quote:Measurement methods
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel through a specific test engine with a variable compression ratio under controlled conditions, and comparing these results with those for mixtures of isooctane and n-heptane.
There is another type of octane rating, called Motor Octane Number (MON) or the aviation lean octane rating, which is a better measure of how the fuel behaves when under load. MON testing uses a similar test engine to that used in RON testing, but with a preheated fuel mixture, a higher engine speed, and variable ignition timing to further stress the fuel's knock resistance. Depending on the composition of the fuel, the MON of a modern gasoline will be about 8 to 10 points lower than the RON. Normally fuel specifications require both a minimum RON and a minimum MON.
In most countries (including all of Europe and Australia) the "headline" octane that would be shown on the pump is the RON, but in the United States, Canada and some other countries the headline number is the average of the RON and the MON, sometimes called the Anti-Knock Index (AKI), Road Octane Number (RdON), Pump Octane Number (PON), or (R+M)/2. Because of the 8 to 10 point difference noted above, this means that the octane in the United States will be about 4 to 5 points lower than the same fuel elsewhere: 87 octane fuel, the "regular" gasoline in the US and Canada, would be 91-92 in Europe. However most European pumps deliver 95 (RON) as "regular", equivalent to 90-91 US (R+M)/2, and even deliver 98 (RON) or 100 (RON).
The octane rating may also be a "trade name", with the actual figure being higher than the nominal rating.[citation needed]
It is possible for a fuel to have a RON greater than 100, because isooctane is not the most knock-resistant substance available. Racing fuels, straight ethanol, AvGas and liquified petroleum gas (LPG) typically have octane ratings of 110 or significantly higher - ethanol's RON is 107 (MON 89, AKI 98) reference[2]. Typical "octane booster" additives include tetra-ethyl lead and toluene. Tetra-ethyl lead is easily decomposed to its component radicals, which react with the radicals from the fuel and oxygen that would start the combustion, thereby delaying ignition. This is why leaded gasoline has a higher octane rating than unleaded."
I dont understand what NewJerZ meant by "tuned on the wrong octane". You don't fill it with super (93) normally?
Old May 13, 2008 | 04:32 AM
  #128
Julian@MRC's Avatar
Julian@MRC
Thanks for the lesson on Octane ratings...
what NJZ meant, was that halfway during the tuning session(because he brought me a car to tune with Less than a 1/4 Tank of gas, and we didnt notice till she was all straped in...) We ran out of gas.
He went to the gas station with a 5 gallon gas can and we filled up on the dyno. After a few pulls the gains we made, were negated, and the power dropped to original power..
We were perplexed, despite leaning the A/F from a low 11's High 10's stock, to 13.0-12.5, we didnt gain power..
Yesterday, JNZ PM'd me and advised me he found the CC reciept from the gas station and the idiot at the gas station gave him 87octane...
That right....87 octane...
So we made 290 on 87 OCTANE....I will SAY THAT AGAIN< 8 7 O C T A N E !!!
Old May 13, 2008 | 04:35 AM
  #129
Z1 Performance
Former Sponsor
gotcha
the octane post wasnt for you..it was for the guy above you, from australia, who asked the differences
Old May 13, 2008 | 06:41 AM
  #130
New JerZ's Avatar
New JerZ
FYI everyone... In New jersey you are not allowed to pump your own gas so the gas tank was filled by an attendent who didnt listen... I ALWAYS put 93 in my car. But yes its pretty sick we made 290 whp with the ECU pulling timing. With test pipes and premium gas and possibly some advancing of the timing with the emanage, I am very excited to see what we can make!!!
Old May 19, 2008 | 10:09 PM
  #131
kennedy's Avatar
kennedy
I hate you guys.... I am now to looking for an emanage and someone to tune the car. Looks like suspension can wait.
Old May 26, 2008 | 01:09 PM
  #132
sebg350z's Avatar
sebg350z
can someone tell me if the plenum spacer is good and whats a good brand for a 350z 2007? is it easy to install?
Old May 26, 2008 | 01:12 PM
  #133
New JerZ's Avatar
New JerZ
...........there is no spacers for 07+ since the ...................nevermind. Your platium is plastic and the spacers are metal. .
Old May 28, 2008 | 07:31 AM
  #134
kennedy's Avatar
kennedy
Did they ever re-dyno you with premium?
Old May 28, 2008 | 10:29 AM
  #135
New JerZ's Avatar
New JerZ
not yet... I got the test pipes installed but didnt get re dyno'd yet... Hopefully next week. I expect to be around 310+ at the wheels once its done.
Old May 28, 2008 | 12:41 PM
  #136
chinny's Avatar
chinny
i have the test pipes on and the turboxs. i have the greddy emanage laying around and i havent had time to install it... i dont want to start splicing my car apart since its brand spanking new... i wanted to know whats the best way to install the greddy... anything i should let the shop know ?
Old May 28, 2008 | 12:42 PM
  #137
chinny's Avatar
chinny
also, can the greddy be used to control timing for nitrous? sorry for all the stupid questions guys but i think im ready to go into the next step and put the emanage on then juice her up. im still doing alot of HW on nitrous so thats going to have to wait atleast a month.
Old May 28, 2008 | 12:43 PM
  #138
New JerZ's Avatar
New JerZ
ask either julian @ MRC or Jermaine from TurboXS (OP) they did the work
Old May 28, 2008 | 12:44 PM
  #139
chinny's Avatar
chinny
i will be sure to PM them! hopefully we can attain that 310whp without F/I or nitrous new jerz!! i cant wait man!
Old May 28, 2008 | 01:37 PM
  #140
New JerZ's Avatar
New JerZ
i assume 310-315 whp peak but I am hoping for some real strong mid range power increases. I also have nitrous install pendng (45-55 shot).... We will see.
