Clutch pedal click sound
This just in:
My car is now making a clinking, loose metal piece, sound that seems to be around the middle of the cabin. Might be something loose in the transmission (great).
Looks like I'll have another thing for the dealership to check out.
Originally Posted by chefsz
had the same problem, easy fix
get on your knees with a flashlight and a can of wd40
spray it on any joints, and you will have about 6 months till you have to do it again
i'm still having the dealership check it out just in case. the shop is pretty good over here.
Same clicking problem, right here. It started a few weeks ago, then the clutch failed and got stuck to the floor two days later. Took it to Nissan and had the recall work done. Had it for 400 miles since the recall work, it still clicks but the clutch works at least.
Yeah I'm pretty sure this is normal if you're just talking about the click sound that happens when you disengage the clutch. I can't really explain due to not being a pro but I am pretty sure that it is normal.
Semi-old thread. The following link is the OP's fix that he posted two weeks after this one:
https://my350z.com/forum/vq35hr/3604...pop-fixed.html
Originally Posted by SOLO-350Z
You guys are talking about a problem that is normal. The clicking noise. It has done it on all the 350z years. Get use to it.
