Grounding auto trans
Old Jun 20, 2008 | 10:41 PM
jgregory124's Avatar
jgregory124
Default Grounding auto trans
I have read numerous times that on the 5at that if you ground the trans some of the delay goes away....where do you ground the trans, from what point on the trans to what point on the body? what gauge wire?
Has any one done this.....what are the results? any help would be great
Old Jun 21, 2008 | 06:39 PM
jgregory124
bump
Old Jun 22, 2008 | 09:10 AM
reserved's Avatar
reserved
As far as I know, a valve body upgrade is all you can do.
Old Jun 22, 2008 | 11:21 AM
jgregory124
right but from what Ive read that doenst take away all lag........any one else know any thing about grounding the trans....is the delay a voltage spike or what is it?
Old Jun 22, 2008 | 11:52 AM
reserved's Avatar
reserved
True, but the difference it does make is pretty dramatic, even with a conservative upgrade like the Stillen version. My guess is it will never be possible to take away ALL lag.
Old Jun 23, 2008 | 09:06 AM
Billhyco's Avatar
Billhyco
i say upgrade the valve body and quit being a poonanny
Old Jun 23, 2008 | 09:25 AM
jgregory124
I know how you feel about it Bill.......Might be doing this very soon
Old Jun 23, 2008 | 12:17 PM
Hoooper's Avatar
Hoooper
if youre doing extra grounding points, all you need to do is ground on bolts nearest the sensors. obviously dont ground to the sensor but anything close is fine. also, run whatever gauge you like. typically, the bigger the better so if you run like 4-8 gauge its usually enough, but you could run 000 if you wanted
Old Jun 23, 2008 | 02:50 PM
Billhyco's Avatar
Billhyco
is it best to ground directly to the battery or just a common ground on the block/frame/whatever we can find?
VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!VALVE BODY!!
Old Jun 23, 2008 | 05:10 PM
jgregory124
hehehe........I guess I know what my next mod will be
Old Jun 24, 2008 | 08:18 AM
folgrz's Avatar
folgrz
do this....
http://www.activetuning.com/products...stallation.php
EDIT nvm, just realized u had an 07
your best bet would be the big 3
http://www.caraudio.com/forum/showthread.php?t=152355
burglapfd
Dec 6, 2020 01:04 PM
Jambo016
Sep 16, 2016 01:08 PM
_bit
Oct 2, 2015 07:49 AM
