Exhaust leak from AAM test pipes
Old Jan 11, 2009 | 01:35 PM
Jae350z's Avatar
Jae350z
Default Exhaust leak from AAM test pipes
Hi guys, I have the AAM test pipes installed on my car with the stock exhaust. I know I have an exhaust leak from the header to the test pipe on the passenger side because i can hear it and when i go under the car i could feel the ait leaking. I have the original dounut gasket installed but it's still leaking. I was wondering if I install an extra 3 bolt gasket on both side maybe it could stop the leak? My question is what is the inside diameter of the stock header to the cat so I can get a 3 bolt gasket with the right diameter. Is it 2.25" or 2.5"? I know the aam is 2.5", so let say if the stock header id is 2.25" should i get a gasket that is 2.25 or 2.5"?
thanks.
Old Jan 11, 2009 | 08:37 PM
kramykram's Avatar
kramykram
just hit up berk they sell the gasket you are looking for and i would not even use that doughnut gasket.
Old Jan 11, 2009 | 08:50 PM
singh's Avatar
singh
_______________
Get a 2.25" gasket. I believe the inner diameter of the oem manifolds is 2.25"..
Old Jan 12, 2009 | 04:43 AM
baspence's Avatar
baspence
and remember to put lots of the copper RTV. let it set for little while or run but dont floor it before it gets a chance to dry.
Old Jan 12, 2009 | 07:45 AM
kramykram's Avatar
kramykram
they make a graphite gasket now not just the copper one. no need for rtv.
Old Jan 13, 2009 | 12:58 PM
baspence's Avatar
baspence
wasn't aware. when I did mine they didn't have those. thanks for the info though, I might have to redo mine when I get motivated.
Old Jan 13, 2009 | 02:40 PM
Jae350z's Avatar
Jae350z
thanks for the help guys. I called Berk for the gasket and they told me i can use a their graphite 2.5" gasket. I would thought i need a 2.25 gasket but he said that i can use a 2.5 as long as the ID is not bigger than 2.5", i dunno but that seems to be right to me.
Old Jan 13, 2009 | 03:28 PM
kramykram's Avatar
kramykram
yes it is right don't worry
sales@czp
Sep 23, 2019 03:30 PM
issyz
Jul 2, 2017 03:04 PM
codek
Sep 28, 2015 03:03 AM
