What Oil are you running in your HR?
Old Apr 13, 2010 | 09:41 AM
  #181
Goo$e's Avatar
Goo$e
^ that is the best info. When someone uses a oil for a while, then takes the heads off and looks at the outcome. Good stuff. We need more of that kind of info.
Old May 5, 2010 | 04:06 PM
  #182
bardabe's Avatar
bardabe
mine is due in about 500 miles, hasn't burnt anything. : ) Love that European Formula!
Old May 29, 2010 | 08:38 AM
  #183
Phantom Menace's Avatar
Phantom Menace
anyone have any experience with nissan ester oil (5w30)?
Old May 30, 2010 | 03:56 PM
  #184
BenchTT's Avatar
BenchTT
Default M1 040
Newest lab report. All reports are M1 040
Old Jun 4, 2010 | 09:48 AM
  #185
Shawz1102's Avatar
Shawz1102
Looks like i'm going to switch out to full synthetic on my next oil change. previous owner never switched to synthetic after 10k miles.
Old Aug 11, 2010 | 07:37 AM
  #186
J. Dub's Avatar
J. Dub
I run whatever resolute runs in his car.... Which after reading almost every one of his post on this forum I still am not sure what oil he runs
Old Aug 11, 2010 | 09:33 AM
  #187
MDHRZ's Avatar
MDHRZ
Originally Posted by Goo$e
So I take it the top 2 oils are...
Mobil 1 0w-40
Castrol Edge
I'll be switching to Mobil 1 0w-40 on my next oil change..
Old Aug 11, 2010 | 10:17 AM
  #188
Chris@FsP's Avatar
Chris@FsP
Vendor - Former Vendor
I've been running the 0w-40 in our shop car for a while now, and it's what I put in customer cars as well. Good stuff.
Old Aug 11, 2010 | 01:29 PM
  #189
kyle22's Avatar
kyle22
Im running mobil 1 0w 40.
Old Aug 11, 2010 | 03:24 PM
  #190
singh's Avatar
singh
_______________
i just bought more M1 0w40 from autozone they had a special going on $34.95 for 5 quarts M1 oil and M1 oil filter!!
Old Aug 11, 2010 | 05:22 PM
  #191
MDHRZ's Avatar
MDHRZ
Nice, I just looked it up. Offer is good until August 23.
Old Aug 11, 2010 | 08:19 PM
  #192
bardabe's Avatar
bardabe
just did that to my car, i think I like German castrol Better
Old Aug 11, 2010 | 08:58 PM
  #193
AadosX's Avatar
AadosX
With German Castrol my oil pressure gauge reads almost 0 at idle..
Old Aug 12, 2010 | 10:37 PM
  #194
bardabe's Avatar
bardabe
mine read a tad above 30psi even after hard track driving and Drifting. get the pressure sending unit checked out. signs of a worn oil pump or something bad waiting to happen.
Old Aug 13, 2010 | 08:48 AM
  #195
AadosX's Avatar
AadosX
I've been to the dealer twice about it. The first time they replaced the sending unit... still reads low. The second time (different dealer) they hooked a manual pressure gauge to it and said it read 12 psi (and that sock was supposed to be 14 psi). They said they wouldn't do anything else because I was not running OEM spec oil or filter (I use the bigger Mobil filter). So unless it's the filter, the GC makes me lose 2 psi? Anyways.. that's not a huge difference.
The dumbest part is that our factory cars are supposed to idle at 14 psi but our gauges translate that to about 30!..? Well at least most of our gauges. -.-
I am pretty sure that when I was on Mobil 1 5W30 my gauge read the norm.. so I plan on switching to something else my next oil change. I don't think it's hurting anything (the GC), but it makes me feel uneasy whenever I look at the gauge.
BTW here are my oil gauge readings:
cold start - 50
after rpms drop at cold start - 25
warm idle - 7
cruising - 30-45
hard acceleration - 60-90
Old Aug 13, 2010 | 09:56 AM
  #196
plumpzz's Avatar
plumpzz
cold start - 50
warm idle - 7
cruising - 30-45
im not sure if it reads psig or just psi.
Old Aug 14, 2010 | 08:27 AM
  #197
Kuhan's Avatar
Kuhan
cold start - 50
warm idle - 7
cruising - 30-45
I had M1 5w-30 with M1 oil filter and the psi was reading normal.
And when I switched to GC 0W-30 with M1 oil filter, the oil pressure is reading actually like yours.
I'm going to switch to M1 0w-40 oil next oil change with M1 oil filter and see what will happen.
Old Aug 15, 2010 | 02:04 AM
  #198
KingBaby's Avatar
KingBaby
Hardest Setting
now running M1 0w-40...
Old Aug 15, 2010 | 01:29 PM
  #199
Phenom's Avatar
Phenom
Toasty
I've been using mobil1 5w30 for about 12,000 miles now
Old Aug 20, 2010 | 08:37 AM
  #200
Taresh's Avatar
Taresh
Originally Posted by Taresh
Hi
I live in Kuwait the temp in summer From 102 f up to 122 in the morning so i lost my owners manual and I downloaded the us spesc it says that I should use 5w30 but the dealer here in Kuwait use 20w50 I have 2008 350z hr so I bouth pennzoil 5w30 I'ts kind of expensive 6.25 $ per litre anyway I noticed that when I stop the car the pressure goes below 30 psi so I freaked out and bought the 20w50 pennzoil after driving 650 miles on the 5w30*
so I'm confused what grade shoud I use I know that the dealer here don't understand anything even the Manager says he don't know and they use 20w50 for all cars all year round (armada -350z-altima-maxima...)*
so plz help*
weather in summer Nights 102 F in the morning up to 122 f
in winter From 45 F up to 85 F
I want to use synthetic but which grade should I use
ps: rp and amosil are not available pennzoil ultra is not available also
what is available pp and mobile 1 and some other
