Clutch&Flywheel or 3.9 gears?? Help
Old Mar 11, 2009 | 03:36 PM
kakashishin's Avatar
kakashishin
Originally Posted by NISMO_558
what adding a clutch and flywheel adds power? really?
I think he means that he loses less hp through the drivetrain thanks to the clutch/flywheel combo, but I could be wrong, lol.
Old Mar 12, 2009 | 09:27 AM
Ataru074's Avatar
Ataru074
Ok.. going back on topic...
at 3.9 gears and clutch/flywheel combo... I'd say... both.
go for the gear if you want to put in also a good LSD...
the clutch is going to wear down eventually, so the dual mass flywheel...
right now looks like there is only the JWT, but if the "combo" is the same of a 370z.. I'm pretty sure that fidanza/act/tilton/exedy/carbonetics will start coming later this year.
honestly I like the design of an act performance flywheel, with the material removed where it matters. tilton competition looks a little too brutal for any street use.
Old Mar 12, 2009 | 02:20 PM
NISMO_558's Avatar
NISMO_558
I was being sarcastic, i realize what he was saying, he just didn't word it correctly.
Old Mar 13, 2009 | 08:38 AM
JZK's Avatar
JZK
So what would be better for an HR?
The 4.08 Gears or the 3.9 Gears? Pro's and con's of each? I can't find a thread where anyone is comparing the two...
Old Mar 13, 2009 | 08:51 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
4.08 cost less, are more readily available, and suit the HR perfectly
sticky post with every ounce of info one could every need
https://my350z.com/forum/engine-and-...installed.html
Old Mar 13, 2009 | 09:03 AM
MDHRZ's Avatar
MDHRZ
Z1 ftw
Old Mar 28, 2009 | 07:59 AM
ambientflier's Avatar
ambientflier
4.08 gears are better for the HR, in my opinion. You're still getting to 60 in 2nd gear (barely), and the acceleration is better than 3.9's. Plus they are cheaper, since they come from the frontier pickup, versus nismo or something for the 3.9's. I guess you would lose a little mileage if you cruise on the highway a lot, but if you mostly drive in the city, then it makes no difference, as you can just cruise around in top gear more.
sherm
Apr 11, 2020 05:21 PM
Sunset350ZR
Nov 15, 2015 05:45 AM
Conway_160
Drag
Sep 29, 2015 08:07 AM
Bodyboarder81
Sep 21, 2015 06:23 AM
