Wierd sound around 1900 rpms in gears 1-3
My 07 HR is making a wierd rattling/vibrating sound around 1800-1900 rpms in gears 1-3. I dont think it makes the sound in 4+. Its not very loud, b/c i have to kill my radio completely to hear it but it is apparent and new and ANNOYING! Its really hard to describe but if you could picture a really f'in loud bumble bee buzzing thats the only sound i can think of two compare it to
any help!!
any help!!
its probably just the trans noise.. which is normal
like if you start from a dead stop using the clutch and no gas, im quite sure its the same sound, if its not the same noise then its something else
im not really sure why im so low in the Rs in 2nd and 3rd guess to save fuel im broke...but the fact is that it never did that b4 and now it does kinda wierd.
Also: at very low speeds in first like when pulling thru a parking lot and turning into spaces it makes a creeking sound when turning the steering wheel either way. Ideas on what this could be?
For the rattling noise you were talking about, it could be the bracket holding the test pipes in place. The bracket bolts onto your testpipes/cats/HFC's and transmission. There are 4 bolts. The rattling could be caused by one of the bolts being loose, try and tighten all 4
wanderingstuden
Jan 28, 2016 07:03 PM
Justin100
Nov 29, 2015 03:58 PM
