How to get 300whp+ on a HR
Old Aug 31, 2009 | 01:09 PM
  #41
Lakeside's Avatar
Lakeside
It wouldn't matter either way! The car will show gains on a Mustang no different then it showing gains on a Dynopack.
The shop that had the Dynopack didn't do as I asked! So to me that is shaddy. They didn't do a base pull before the bolt-ons. Didn't install a wideband! Didn't state how many pulls or what temps/humidity was!
I nolonger do business there! So to me they are not credible...... I would be open to going to a professional shop with a Dynopack to see what they have for results.
But as for the shop that claims to have done a dyno I have to wonder.... I never even saw a print out. So everyone would have to agree thats Bogus!
Old Aug 31, 2009 | 01:10 PM
  #42
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
So, find a Dynojet and run your car and report back. Till then your overly high numbers are ignored.
Old Aug 31, 2009 | 01:14 PM
  #43
03threefiftyz's Avatar
03threefiftyz
Originally Posted by warmmilk
or just adjusting a couple settings on the dyno...
......it is clearly apparent that this dyno is considerable over-corrected.
Old Aug 31, 2009 | 01:27 PM
  #44
Lakeside's Avatar
Lakeside
Next time the car will be on the Dyno will most likely be after I get the Zex kit installed. Program another tune
I need to get a Quote from performance Nissan of L.I for Cam install. They are pretty booked right now boosting a couple Z's. Doesn't help that the one shop I trust is 4 hrs with traffic The car would be alot farther along if that wasn't the case.
Old Aug 31, 2009 | 01:43 PM
  #45
warmmilk's Avatar
warmmilk
you're getting cams? GTM? they're the only ones that i know of that make cams for the hr...
Old Aug 31, 2009 | 01:51 PM
  #46
Lakeside's Avatar
Lakeside
Tomei
http://www.z1auto.com/prodmore.asp?m...ne&prodid=3713
Its the next step for me.
I guess 264's. I just want to do alittle more research and speak to someone about whats best for the future of my car.
Old Aug 31, 2009 | 02:03 PM
  #47
warmmilk's Avatar
warmmilk
thats right, i forgot about tomei
Old Aug 31, 2009 | 02:04 PM
  #48
Lakeside's Avatar
Lakeside
There is also Kelford!
http://www.z1auto.com/prodmore.asp?m...ne&prodid=3676
Not yet available.
Old Aug 31, 2009 | 02:56 PM
  #49
biggersNISMO's Avatar
biggersNISMO
^^ In all sincerity, i don't think you would break 265whp here in the Mile High City. Even if the "altitude" factor is put aside, your at 295whp at best Lakeside on a "fair dyno" at regular altitude. I'm not trying to start beef with you, (i'm a vegetarian) lol
As for cams and spray, i wish you the best of luck. If i had the engine open, i would make one difference. I would go with the GTM 302 cams, with spring and retairners etc, CP Pistons, Eagle Rods, your prefered choice of timing, and that 100 shot of juice.
Might as well go ***** out, right? That's if money ain't a problem bro...
Old Aug 31, 2009 | 03:55 PM
  #50
Phenom's Avatar
Phenom
Toasty
Originally Posted by SOLO-350Z
That dyno is majorly wrong.
Dude how many times do you need to tell me that? There's an entire 7 or 8 page thread about it and half the posts are you bitching about any HR with numbers higher than yours. We all get it, your car is the end all be all HR and any other car putting out better numbers is obviously on a fantasy dyno. I'm sure the OP was looking for worthwhile mods for his car by seeing what other members have experience with, not to start a horsepower pissing contest.
Old Aug 31, 2009 | 04:00 PM
  #51
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Laugh. Actually I was part of that conversation, but not the main people saying that. Mine is a one of the only legit dynos of a HR with almost full bolt ons.
Old Aug 31, 2009 | 04:54 PM
  #52
warmmilk's Avatar
warmmilk
^you still have stock headers, right?
Old Aug 31, 2009 | 05:05 PM
  #53
Lakeside's Avatar
Lakeside
How do you figure? There are several HR's with full bolt-ons! Mine included. The only thing I have not installed is my Injen intakes. Why? Personally I am satisfied with my stock air boxs. Your also in Texas! Climate is vastly differant when comparing Humidity and air temps to Upstate NY.
Old Aug 31, 2009 | 05:31 PM
  #54
his&her350z's Avatar
his&her350z
300rwhp on a make believe dyno. Dynojet it will be hard.
i agree maybe on dyno pack u can make 300 plus wrhp
Old Aug 31, 2009 | 05:32 PM
  #55
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Yep, and headers on the HR are a waste.
  #56
SOLO-350Z's Avatar
SOLO-350Z
'12 TL SH-AWD
Dynojets take into account this.
Old Aug 31, 2009 | 05:44 PM
  #57
his&her350z
HUH Dude use Screen names! I assume your talking about me....
I had a base of 265 WHP on a sh*tty dynopack running lean. After several hours tuning with a base of 302 on a Mustang the car then put down 314 WHP!!!! A Mustang dyno is more true to life. Wheels on the car under load.
edit:
The shop never stated how many pulls they ran on the Dynopack and also never hooked up a wideband. So I rule out thier results completely as to me they are not creditable.........
um mustang dynos read lower numbers and dynopacks read higher numbers the closest u can get to your real whp is a dynojet but they can be wrong to i just bought a 09 cls63 amg they say on dynojet it should be around 410 to 420 rwhp but it was more like 403wrhp . its albout the condtions like for me it was to hot temp was 93 degrees
Old Aug 31, 2009 | 05:48 PM
  #58
03threefiftyz
Generally speaking dynapacks read higher than mustangs...........of course putting a wild correction into the mustang dyno (and vice versa) can swing that. Bottom line is that dyno needs to be recalibrated.
Old Aug 31, 2009 | 05:49 PM
  #59
Lakeside's Avatar
Lakeside
If you had aftermarket headers you wouldn't be saying that!
The stillen headers are far more equal in length then the stock HR headers with an increased tube diameter. I also took some time to file smooth the welds on the collector's and slightly enlarged and smoothed the exhuast ports on the headers. Whether or not this helped any?! lol Who knows! But I took a couple hours to perfect the quality of their product in my eyes.
Old Aug 31, 2009 | 05:53 PM
  #60
warmmilk's Avatar
warmmilk
everyone (very few) that's gotten headers on the hr so far saw gains with them. while peak power didn't go up much, there were good gains through out the rest of the rev range...
with headers and a cooler day, who knows, maybe you'd break 300 whp on a dynojet...
