Kinetix HFC are ceramic !
Old Nov 30, 2009 | 11:27 PM
karletto66's Avatar
karletto66
Default Kinetix HFC are ceramic !
Hi to all...
I'm looking for some good HFC for my new 350z (HR model) and ask for infos at some producers.
Kinetix has written this mail to me:
Hello
On the newer 350Z's and 370Z's we have to use ceramic cats, because metallic cats will throw a check engine light and cause drive-ability issues. The new 350Z's and 370Z's have a very sensitive 02 sensor (wide-band 02) which is non-compatible with metallic cats. Metallic does flow better then ceramic if each cat is the same cell count, so instead we went with a slightly lower cell count to even out the flow numbers. Our ceramic cats will flow the same as any competitors metallic cats but will not throw a check engine light!
Ultimate Racing for example are metallic for sure...
Do you think is better to go with ceramic avoiding CEL (if Kinetix's words are right) or there is no power gain and is simply very similar to original one cat ?
I think that similar flow=similar CEL ! For avoiding cel the difference may be is the quality of "nobles" metals, i remember that ceramic/metallic are NOT the one making cat process but metals put inside it !
I'm wrong???
Thank you !!!
Old Nov 30, 2009 | 11:51 PM
itsjiggajames's Avatar
itsjiggajames
i've had metallic berk HFCs for almost 2 years + 20k+ miles.. not a single issue
Old Dec 1, 2009 | 12:08 AM
Germanguy's Avatar
Germanguy
AAM 2,5" metallic cats for the 07. no issues till now.
Old Dec 1, 2009 | 12:12 AM
diablox1's Avatar
diablox1
I have stillen HFC (metallic) on my '07 HR. they threw a code for a while, which I had to keep erasing. then i installed the non-foulers (aka spacers) on the O2 sensors and i've had no issues/codes since.
Old Dec 1, 2009 | 12:36 AM
User 42426's Avatar
User 42426
Sorry, kinda off topic, but what are the sizes of stillen/crawford/berk hfc? The post above stated that AAM is 2.5 already. Also, im assuming the bigger the better for air flow?
Old Dec 1, 2009 | 01:29 AM
karletto66's Avatar
karletto66
BERK are metallic for sure????
Here in Italy a boy stated his berk's are ceramic, may be he opened it and discover the "surprise"...
Old Dec 1, 2009 | 10:15 AM
Interesting that Kinetix would mention 02 sensor (wide-band 02). Is that not BEFORE the catalytic converter?
Old Dec 1, 2009 | 01:45 PM
INTIMAZY's Avatar
INTIMAZY
Correct. Pre-cat are wideband.
However, it uses that info from the bank 1 o2 sensors and compares them to the secondary. Kinetix could be correct in that the tolerance is now narrower, but I don't know of this being true offhand.
Old Dec 1, 2009 | 07:42 PM
T_K's Avatar
T_K
The secondary are wideband as well on the newer cars.
Old Dec 1, 2009 | 08:47 PM
User 42426's Avatar
User 42426
Berk makes ceramic and metallic hfc. The new ones come with the support bracket as well.
Old Dec 2, 2009 | 01:01 AM
karletto66's Avatar
karletto66
I'm interested in METALLIC one, for my HR 2007 350Z.
SOMEONE knows a seller to Italy ????
I have written to some shops on line but no reply for this HFC !
Kinetix and Adam of Z1 for Ultimate racing very fast...
I would like to have also Berk prices, seems a very good item.
PM also !!!!
Please help a poor italian man !
Thanks to all !
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
silverbullet_Z
NA Builds
24
Nov 14, 2015 02:52 AM
SpartanZ32
Oct 22, 2015 09:36 AM
Calinismo350z
Sep 14, 2015 04:04 PM
