Primary O2 sensors voltages (B1-S1 - B2-S1) / HELP !
Hi Guys,
I'm looking for some help regarding small issue on my 2007 VQ35HR (I don't know if my car's mount with the 234-9072 Denso O2 sensor or 234-9036 one's, but it's no the current issue).
Does someone can confirm me the following figures from the primary O2 sensors voltage with an ODB scan tool.
O2 sensor B1-S1 voltage,
O2 sensor B2-S1 voltage.
At iddle, and 2000 RPM.
The issue is that my O2 sensor B1-S1 voltage is different that O2 sensor B2-S1 voltage:
For exemple when I switch on the car: ~0.450mv for O2 sensor B1-S1 and ~0.800mV for O2 sensor B2-S1 voltage, the difference remain at each RPM level.
And I assume that those voltages should be closers as possible ?
Thank you very much for your help and for your information.
Reason: Mistake
Any CEL? Does it go away after the car warms up? I remember mine being off, but I'm not sure it was by that much. I'll check it on my way to school tomorrow and let you know.
I know this is 4 years old... but you're active as of 5 hours ago.... did you ever resolve this issue. Mine is doing this same thing. With berk hfc and a new b2s1sensor since the resistor failed when installing hfc. Follow up is appreciated
Hi Everyone, I am new to this community, so apologies if I post in the wrong place.
- I got P2A03 code and I replaced the A/F sensor (Bank2 sensor 1) with Germban (Part number: 234-9072)
- I cleared the code, but a week later, the engine light came again. It was P2A03 code again.
- I checked with bluedriver app, and it seems like the O2 sensor is giving voltage reading. What's odd is the sensor1 in both bank 2 and bank1 are not looking similar. My assumption is they should be similar? I'm wondering what's potentially wrong here, given I already replaced the sensor with the correct part number.
If this helps, I want to add that, I measured overall signals as well, Bank1: - VBATT = 13.96V - AF+1 = 2.244V - AF-1= 1.846V - AF+1 to AF-1 = 0.398V - AFH to GND (PWM) = 6.75V
