3.7hr short block to hi-rev 3.5 heads
Old Jan 17, 2011 | 04:17 PM
zheiland's Avatar
zheiland
Default 3.7hr short block to hi-rev 3.5 heads
Hey,Has anyone paired a 3.7HR short block to an aniv. 3.5 HI-REV set of heads?
Old Jan 17, 2011 | 06:00 PM
zheiland's Avatar
zheiland
Default 3.7vhr to 3.5 2005 hi-rev heads
My mechanic is talking to his friends in Japan and they said it can be done.
Going n/a ,bigger injectors,haltech tuned 350whp.I am curious if anyone had
experiance with this application.He also talked of a 12.5 short block 37vhr.
Old Jan 17, 2011 | 11:16 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
The block will work, the piston design is different so a stock VHR block with its stock piston would not be a good idea with HR heads, I would install the HR pistons as well .
Sam
Old Jan 19, 2011 | 02:56 PM
supra crazy's Avatar
supra crazy
Sam
What's different about it?
Old Jan 19, 2011 | 03:02 PM
Sam@GTM's Avatar
Sam@GTM
GT Motorsports
Piston dome design, valve relieve, compression height . They're two complete different chambers designs.
Sam
Old Jan 19, 2011 | 07:32 PM
zheiland's Avatar
zheiland
Default Piston height and rod lenght
As long as the pistons are the same height.You have to consider the longer
stroke either the rods or pistons are a different lenght.
Old Jan 19, 2011 | 07:39 PM
zheiland's Avatar
zheiland
Default You could get custom pistons made.
I was thinking custons piston height with the proper combustion cambers as needed to match heads.
Old Jan 19, 2011 | 07:47 PM
zheiland's Avatar
zheiland
Default Is there any 3.7 or 3.8 crankshafts available?
The other way would be to use the crank out of 3.7 and 3.5 block which
is basically the same.
Old Jan 20, 2011 | 07:07 AM
archangel72's Avatar
archangel72
Sam, would using the HR pistons instead bring the compression down to 10.6:1 instead of 11:1?
Old Jan 20, 2011 | 08:00 AM
redline06's Avatar
redline06
the title seems a bit missleading , hi-rev is the HR motor 07-08 and 09 convertible 350z. but then in post #2 you wrote "3.7vhr to 3.5 2005 hi-rev heads" those would be heads off of a rev-up motor from 05-06 manual trans Zs. just trying to clear it up so you dont get the wrong information before you start spending money
Old Jan 20, 2011 | 10:56 AM
zheiland's Avatar
zheiland
Default I stand corrected
Indeed i meant to say rev-up.
sherm
Apr 11, 2020 05:21 PM
Depravity
Oct 1, 2015 04:49 PM
