revised HR build :D
Old Jan 10, 2012 | 04:16 PM
  #121
SE5spd's Avatar
SE5spd
Originally Posted by ace32x
harness bar lol. no cage currently
be safe.
Old Jan 10, 2012 | 04:35 PM
  #122
ace32x's Avatar
ace32x
Originally Posted by SE5spd
be safe.
yea i know its not the safest xD, waiting till i get a bit more cash before i cage it
Old Jan 27, 2012 | 07:27 AM
  #123
ace32x's Avatar
ace32x
small update, got the hks 2 step plugs in last night and tossed it back on the dyno, that cleared up the missfire completely everything is real smooth now and picked up another 15 whp and 8 tq. But we found out the drop up top is due to the wastegate spring on the passenger side not holding. Ordering some 20lb springs today and going to get those swapped in and then back on the dyno tuesday! its peaking 24lbs before the wastegate opens prematurely and then is dropping to 18 and then off to 14-15 range so hopefully should be able to pick up some good power with another 5 lbs of boost
Old Jan 27, 2012 | 07:03 PM
  #124
SoCal07HR's Avatar
SoCal07HR
Sick. Videos please.
Old Jan 27, 2012 | 09:10 PM
  #125
ace32x's Avatar
ace32x
I'll have some tommorow got a contour from my buddy and there's a big multi forum meet so ill have some shenanigans recorded for sure :P
Old Jan 27, 2012 | 10:00 PM
  #126
johnwigs's Avatar
johnwigs
soooooo... the HR manifold holds 24lbs? there was talk of GTR manifold (which won't work without some serious fabwork) doesn't motordyne make an intake for 370? it should bolt to an HR... oh and GTX3071's exist now... one of the first one is on a 500hp SR20 sand rail, and two more are going on a VQ38DETT in an S13... good build... what would you have changed (not needed in the build)?
Old Jan 28, 2012 | 12:14 AM
  #127
ace32x's Avatar
ace32x
yea manifold is holding fine so far, it grows when boosting though lol kinda sketch to watch.
as far as changing, since i had half the build set up for my stock block set up with no intention to build it for awhile it kinda screwed me, i would have picked up some 1k cc injectors, had my exhaust manifolds made t3 instead of t2. twin gtx 3071r's with a 1.06 AR. other than that nothing im liking everything so far
Old Feb 2, 2012 | 07:11 PM
  #128
ace32x's Avatar
ace32x
update
new springs in car made 28 psi on the gt2871's! also that same run it expanded and cut the coupler on the passenger side pipe going in to the bottom of the IC thus causing a big boost leak.
tommorow were going to weld on a little more piping so we can run a smaller coupler so it doesnt expand as much and cut itself on the tclamp again. it was also spinning 5th gear that run so going to add some weight in the rear to try and help that
Old Feb 2, 2012 | 07:29 PM
  #129
johnwigs's Avatar
johnwigs
1.06 AR is allitle too big IMO... yes you will get a big peak horsepower number but then your boost will come in later and harder... if thats your style then thats a way to go... parts seem to break when a sudden surge of power is sent through them instead of a more gradual with a smaller A/R and a flatter torque curve
Old Feb 2, 2012 | 07:45 PM
  #130
ace32x's Avatar
ace32x
are you saying if i had 1.06 AR's?
i have .86 AR on my 2871's man
Old Feb 2, 2012 | 07:59 PM
  #131
johnwigs's Avatar
johnwigs
??? now I am confused... the bigger your A/R the less exhaust restriction is in the turbo causing more "lag"
Old Feb 2, 2012 | 08:14 PM
  #132
ace32x's Avatar
ace32x
correct. but i have gt2871 .86AR turbo's.... theyre not laggy at all i have 600+ ft lbs of torque by 4k rpm
Old Feb 2, 2012 | 08:58 PM
  #133
johnwigs's Avatar
johnwigs
well a 3071 is the same turbine wheel with a bigger compressor (so I thought)... unless I'm missing something
Old Feb 2, 2012 | 09:52 PM
  #134
ace32x's Avatar
ace32x
my mistake lmao forgot about our previous convo. i made a typo aswell i meant twin 3076's not 3071's. its just a street car that doesnt really see anything from a dig. plenty of air in 4th gear on the freeway so spool wouldnt be an issue
Old Feb 7, 2012 | 06:56 PM
  #135
ace32x's Avatar
ace32x
turns out it did f!ck the radiator, pressurized the cooling system and the radiator leaked like a fiend out of the top seal all along the top and the bottom.
ordered a koyo radiator that will be here next week, swapping that over and giving it a go again
Old Feb 8, 2012 | 03:42 PM
  #136
johnwigs's Avatar
johnwigs
Why did your radiator blow? Did you overheat? Was the car getting hot before hand? I hope its not head gasket or cracked cylinder liners
Old Feb 29, 2012 | 12:05 PM
  #137
ace32x's Avatar
ace32x
it was getting pressure in the overflow tank (looks like failed headgasket) and pressurized and back fed into the radiator i imagen and pushed out through where the plastic is crimped by the aluminum.
Old Feb 29, 2012 | 12:07 PM
  #138
ace32x's Avatar
ace32x
on a side note the motor is out and we are tearing it down to locate the problem.
i ordered some other goodies while its apart.
Picked up some jwt 262 in 262 out cams with springs and shims.
and a pair of gt3076r .86AR snails
Old Feb 29, 2012 | 03:34 PM
  #139
SoCal07HR's Avatar
SoCal07HR
Sorry to hear about your issues. Good luck.
Old Feb 29, 2012 | 03:52 PM
  #140
ace32x's Avatar
ace32x
hopefully will know more in an hour or so, we'll see how torn down the block is
