Couple possible issues after tuning
Old Sep 2, 2011 | 08:30 PM
Mike Anthony's Avatar
Mike Anthony
Default Couple possible issues after tuning
I did not put this in the tuning section because I'm not sure if these problems are related to the recent tune I had done or not.
I had an exhaust system installed, and a tune done. Turned out the exhaust was a little too loud for me so I put the stock back on and got it re-tuned (with osiris). Now that it's been tuned, I think I've noticed some differences in the responsiveness of the throttle when accelerating. Before it was tuned I never had any issues. Now, sometimes it takes a second after pushing the pedal down for the car to actually start going. I've only driven it for about an hour total, and it seems like it mostly does it in second gear. And the second issue I guess would be that while accelerating (again I only noticed it when flooring it in second gear) that it seems to be kind of uneaven. Not really sure how to describe it. But from 1500 to about 5500 rpms it feels like it pulls harder at certain rpms and some power drops off at different rpms. Is this characteristic of tunes? Sorry for my inexperience, this was my first tune.
Also, after the tune, I now hear popping coming from my exhaust every now and then. Usually when letting off the gas or giving it gas there is some popping coming from the exhaust. Never did any of this before the tune.
If anyone has any advice or suggestions for me I would be very thankful. Thanks
EDIT: In case it matters, my car is a 2007 Nismo.
Old Sep 3, 2011 | 08:45 AM
ronn1's Avatar
ronn1
I have same engine (08 HR not Nismo) with Osirus tune and had it tuned prior to cataback exhaust being installed. Never retuned with catback, since it's really not required (no test pipes or HFC). I found better response and acceleration after the tune and even better after the catback added (no additional tune). Absolutely no problems. I strongly suggest you take it back to the tuner and do another dyno tune..something's not right. You really didn't need to retune after you put the stock exhaust back on UNLESS you had HFC or test pipes on . Maybe something is off with the stock exhaust..a leak perhaps?
Old Sep 3, 2011 | 09:54 AM
tylerxfire's Avatar
tylerxfire
who tuned it? sounds like u got a crap tune...exhaust was too loud....muahahahahaha
Old Sep 3, 2011 | 10:46 AM
0jiggy0's Avatar
0jiggy0
Go back to stock. Punch that tuner in the face and find a new one.
Old Sep 3, 2011 | 12:01 PM
ace32x's Avatar
ace32x
Sounds like your tuners a noob
Old Sep 3, 2011 | 12:19 PM
SE5spd's Avatar
SE5spd
go get tuned somewhere else, or ask your tuner to put your stock map back on and call it a day.
Old Sep 3, 2011 | 12:43 PM
Mike Anthony
Yeah I guess I'm gonna have to look into this. The stock exhaust they put back on sounds just slightly louder than it did before, maybe there's a leak. And yeah, I'm thinking the tune was off... it wasn't really a full retune, he said he just wanted to do a touch up to make sure it was all good.
Do you guys know of any good tuners near northern va?
Old Sep 3, 2011 | 12:44 PM
Mike Anthony
Although it was tuned at AAM. They seem fairly popular
Old Sep 4, 2011 | 01:48 PM
67ZNISMO's Avatar
67ZNISMO
AAM is pretty reputable so I doubt it's the tuner. Are you running any sort of after market cats? Interesting to hear that you "pop" on a stock exhaust. Check your exhaust setup to see if you have any leaks and clarify with your tuner on what map he reflashed you with. You might want to check your MAF sensor as well...could be dirty and causing throttle response issues.
Old Sep 4, 2011 | 02:51 PM
Italianjoe1's Avatar
Italianjoe1
Car should pull smoothly with a tune, shouldn't feel surging under power at all. Don't know why you bothered to re-tune with just an exhaust change, but whatever. Take it back and ask them to check it out.
Old Sep 9, 2011 | 01:01 PM
Mike Anthony
Actually, I didn't know this before, but I THINK they left the HFCs on my car when they put the stock exhaust back on. Do HFCs commonly cause the popping sounds? The throttle response issues have pretty much gone away, I don't know what was causing it but I'll look into it.
It wasn't a re-tune. He just said he wanted to look at the tune and do any touch ups that might be necessary after switching back. So I said sure. And it was free.
nanotech
Oct 2, 2015 05:02 AM
350z82
Oct 1, 2015 06:25 PM
