Oil Cooler Question
Old Nov 13, 2011 | 11:01 AM
Moonlightthecat's Avatar
Moonlightthecat
Default Oil Cooler Question
So, I don't know if this will work. I have a PC water-cooling radiator this one
Diagram of pressure drop vs flow rate
I was wondering if this would actually work as an oil cooler or would the pressures cause it to burst. I use one of these in my desktop running mineral oil at a flow rate of 80 gallons an hour. Now I know the oil that is used in the Z is a few times thicker. Some insight and opinions on this would be nice. These radiators are made of solid copper and would dissipate heat in the oil very nicely. I could easily head to home depot and get all the parts needed to put this on the Z.
Old Nov 13, 2011 | 11:13 AM
SE5spd's Avatar
SE5spd
Why do you need an oil cooler?
Old Nov 13, 2011 | 11:16 AM
Moonlightthecat
I do track days and constant mountain driving?
Old Nov 27, 2011 | 05:32 PM
ekelly36's Avatar
ekelly36
I think you would be better off just buying a decent sized / right sized oil cooler.... even if you did adapt that to work with your Z you would always worry about it to some level.... If you get a oil cooler that is MADE to work on the Z then you know it is doing its job... less worry.... IMO...
Old Nov 27, 2011 | 05:37 PM
Spork's Avatar
Spork
Wait, wait, wait... you're asking if you can use a PC cooler on your car as an oil cooler??? Lol.
Just buy a used one if you don't have much money to throw around.
Here's a picture of mine, showing a rough example of sizing to keep in mind.
Old Nov 27, 2011 | 06:36 PM
Flo-ridaZ33's Avatar
Flo-ridaZ33
I have a Stillen for sale if you want it... PM me.
Old Nov 27, 2011 | 06:51 PM
ekelly36's Avatar
ekelly36
yea you need an oil cooler that is designed for your car.... I only see bad things happening if you use a cooler not meant/designed for the operating conditions of a sports car. Im pretty sure the oil gets a lot hotter in your Z then it would in a computer hehe
Old Dec 13, 2011 | 02:59 PM
97supratt's Avatar
97supratt
+1 Oil starts to operate at around 220 degrees on upward. I'm sure that cooler would work to a certain degree, but it wouldn't work long.
Most of the time, fittings & lines cost more than the actual oil cooler itself. I would invest in a bigger core to get better cooling. The last thing you want is an oil leak.
burglapfd
Dec 6, 2020 01:04 PM
issyz
Jul 2, 2017 03:04 PM
Stevo Z
Oct 3, 2015 09:14 PM
Rowlett
Misc.
Oct 2, 2015 10:38 AM
