"Gravity clutch/flywheel kit" Need info
Old Oct 15, 2012 | 06:26 PM
jbwrecked's Avatar
jbwrecked
Default "Gravity clutch/flywheel kit" Need info
Has anyone had any experience with this brand kit?
http://www.wcpdiesel.com/transmissio...lutch-kit.html
^^Thats the link
I'm about to pull a trigger on a 2007 350z and it has its clutch and flywheel replaced by this brand and I've personally never heard of it.
Same one, different name, same part number
http://www.jscspeed.com/catalog/Niss...ssan_350Z.html
http://swiftmotorsports.com/index.ph...oducts_id=2448
Any info helps, thanks guys
Old Oct 16, 2012 | 04:10 AM
jbwrecked's Avatar
jbwrecked
Reboomping this for some help. Anyone even heard of these?
Owner of the HR Z tells me he does get chatter from it but if you get it from the JWT clutch then I wanna know how bad it really is on this one
Old Oct 16, 2012 | 06:58 AM
redline06's Avatar
redline06
Never heard of it but youll get chatter from pretty much any flywheel.
Old Oct 16, 2012 | 08:12 AM
jbwrecked's Avatar
jbwrecked
Damn ok. Yea I was thinking if I get chatter from a reputable flywheel aka JWT or so, and get chatter, I can only imagine the chatter on a cheaper flywheel will be a little worse. Thanks!
Old Oct 16, 2012 | 08:15 AM
doshoru's Avatar
doshoru
Even the stock clutch/fly setup has a fair amount of chatter. Definitely more than on any other manual I've driven.
Old Oct 16, 2012 | 08:38 AM
jbwrecked's Avatar
jbwrecked
Think it may just be Z's? I have an 03 G coupe and theres no noticeable chatter here. Looking at an 07 Z.
Also is the chatter when the clutch pedal is pushed in or when its untouched. Saw a video and showed difference between the 2
Old Oct 16, 2012 | 08:54 AM
musubi's Avatar
musubi
The chatter you're referring to occurs when the clutch is engaged. From my readings, some level of chatter is present in any setup you choose, stock or aftermarket. I believe weight of the flywheel plays a factor in the amount of chatter you'll get. The lighter, the more chatter, and JWT is considered on the lighter side. I'd search for a heavier flywheel, if you're in the market. Or just go back to the stock DMF, which has the least amount of chatter.
Old Oct 16, 2012 | 09:58 PM
jbwrecked's Avatar
jbwrecked
Sweet just wanted to make sure. And yea I believe it is pretty much dependent on the weight of it. Apparently this one is 17.5 and I believe JWT is 14.5 so I'm hoping its not too bad.
Only reason I ask is because my G coupe might sell soon and am thinking of picking up a used Z which has this aftermarket clutch/flywheel and I had never heard of it. So we'll see how that goes.
Also are there reports where the chatter decreases through use? I guess I'm mainly asking those of you with lightweight flywheels who have had em for I guess 40k+ miles or so. Not a big deal but just a thought.
Thanks!
Old Nov 7, 2012 | 10:23 AM
ZSpeedPerformance's Avatar
ZSpeedPerformance
Vendor - Former Vendor
The only way to reduce the noise is better trans fluid with a lighter flywheel, We stock and use Motul Gear 300 and it keeps them pretty quiet. Big difference over the stock fluid
Old Nov 7, 2012 | 11:06 AM
Z33Garage's Avatar
Z33Garage
I thought all the tranni chatter came from the nissan throwout bearings...
Old Nov 7, 2012 | 12:19 PM
ZSpeedPerformance
The rattle in the trans when going to single mass flywheel is caused by the high compression engines in the new cars, The Dual Mass flywheels dampen these "pulses" from the engine and prevent them from being transmitted into the trans.
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
ddegrande21
Sep 6, 2015 11:15 AM
