Slave Cylinder problem
Hey guys, first post!
My name is David, I'm cuban raised in Miami, Florida.
Well I have a beautiful 2008 350z (MT), Which I've owned for 6 months so far. Anyways yesterday while driving when I stepped on the clutch to shift gears, the clutch pedal went all the way back but wouldn't come up, so I had to lift It up with my feet. When I got home I checked the fluid on the reservoir and it was completely empty. I filled it up and got the clutch working again (thought the problem was fixed) drove to my friends house and on the way the same thing happened. The clutch just fell down and wouldn't come back. Popped the hood and noticed the reservoir was empty again, so it had to be leaking. Instead of towing it back home I filled up the brake/clutch fluid again and was enough to get home. I checked the bottom of the car and it was leaking from what seemed the slave cylinder. My question now, would the transmission have to be lowered to replace the slave cylinder? And if yes about how much I'm I looking on spending on this?
Thank you guys for your time, and have a great day.
🙌🙌My name is David, I'm cuban raised in Miami, Florida.
hey David from Miami
unfortunately the HR z were equipped with BS slave cylinder (CSC), and its time for you to upgrade to a heavy duty CSC and master cylinder while you at it.... if you replace it with OEM parts it will happen again and again. Zspeed sells a kit at a good price for an aftermarket kit. prob $500ish
read this
https://my350z.com/forum/engine-driv...-cylinder.html
370z and Hr Z 07-08 share same transmission
http://www.the370z.com/diy-section-d...ed-hd-csc.html
read this
Welcome to the forum! The first two posts are correct, and you'll need a new clutch slave cylinder (CSC). As to how much it'll cost, labor rates vary from area-to-area, but you might consider doing it yourself (there's a DIY on here), if you have the tools and ability. Otherwise, a qualified tech will probably charge between 3.5- 4.0 hours to do it for you.
I did the full zspeed kit, with the upgraded slave, braided line and wilwood master. Much better stuff than stock parts, although my stock parts were still working, I just changed the clutch due to slippage under power and upgraded everything while I was in there.
