My 350z HR dyno tune graphs
Old Aug 11, 2015 | 08:57 PM
07HR's Avatar
07HR
Default My 350z HR dyno tune graphs
Car had around 112k miles when dyno tuned, mods are fujita intakes, cnt racing test pipes (ark look alike), magnaflow x pipe w/ muffler, hks replica with h pipe cut out and replaced by x pipe. tranny and whiteline differential mount/bushings. btw: (this dyna-pack came out this year & is modified to read like a dynojet)
274whp 07 350z hr before tune w/ mods (listed above). Can anyone explain that weird dip at the top end?
After the tune. 286whp dip fixed through tune I'm still not sure as to why it stops making power so early? Hp peaks at 6358 rpm. Is this common?
Old Aug 12, 2015 | 07:32 AM
illphildawg21's Avatar
illphildawg21
If remember correctly, I read that peak HP is generally somewhere in the 6k RPM range, so it seems normal to me for just bolt on's, but I could be wrong.
Old Aug 12, 2015 | 08:29 AM
HRMoneyPit's Avatar
HRMoneyPit
Healthy numbers. If i made that on 91 I'd be happy. Wonder what i could make on cams in the future too
Old Aug 13, 2015 | 10:24 PM
07HR's Avatar
07HR
I just thought it would be a lil bit higher for an HR. My tuner said it might be my mods, but who knows. I'm still wondering why that strange top end dip was there though?
Old Aug 14, 2015 | 01:59 AM
Pengu's Avatar
Pengu
Could be the dyno. How does the tune feel?
Old Aug 14, 2015 | 04:01 AM
travlee's Avatar
travlee
Master
that looks adjusted to be more like a mustang (read low), i hit 286 on one (but i had about half your miles)
Old Aug 14, 2015 | 10:31 AM
07HR's Avatar
07HR
Hmm didn't take the dyno into consideration. As for the tune, I did feel like it pulled a little better afterwards. I wanted to hit 290+ whp but I am satisfied for now.
Old Aug 14, 2015 | 10:33 AM
travlee's Avatar
travlee
Master
its just a number, if you are satisfied is all that matters
Old Aug 15, 2015 | 09:07 AM
Frostydc4's Avatar
Frostydc4
Do you have a tune?
To me it looks like a slight ping
Old Aug 19, 2015 | 09:25 AM
StuLax18's Avatar
StuLax18
General & Tech Moderator
Originally Posted by Frostydc4
Do you have a tune?
Since it went away after the tune this seems to be the likely case. Happens a lot.
Old Aug 19, 2015 | 10:04 AM
Zazz93's Avatar
Zazz93
Do you have a tune?
+1, specifically for the slight dip right after peak, but in all looks ok. If that was detonation, you may want ask them to update the tuning.
Whiskers1996
Tuning
Aug 1, 2020 04:09 PM
seagrasser
Oct 11, 2015 03:27 PM
NissanZcrazy
Sep 23, 2015 07:59 AM
