Help! Changing clutch and stuck on hard line
Old Mar 27, 2020 | 06:49 AM
vqliam's Avatar
vqliam
Default Help! Changing clutch and stuck on hard line
So I’m trying to replace the clutch and I’m at the point of dropping the transmission, there’s a hard line attached to the master cylinder (I believe?) and you need a 10mm open end wrench to remove it. No matter what I try it won’t turn and I’m afraid the wrench is going to round the nut. Anybody else encounter this issue or know a way around it?
Old Mar 27, 2020 | 07:48 AM
travlee's Avatar
travlee
Master
what year of car?
vqliam's Avatar
vqliam
Originally Posted by travlee
what year of car?
2007
Old Mar 27, 2020 | 07:52 AM
travlee's Avatar
travlee
Master
you will have to disconnect it, if its what i think it is its the line for the slave cylinder. i cant remember how i took mine off though
Old Mar 27, 2020 | 08:46 AM
Mully's Avatar
Mully
A line wrench is a must. An open-ended wrench is very likely to strip it. If you don't have a set, they are worth the investment (cheap). They were the first tool I bought myself when I started building trucks and have proven to be indispensable.
Old Mar 27, 2020 | 11:45 AM
Heel Til I Die's Avatar
Heel Til I Die
If you can pop off the U-shaped metal clip with a set of pliers, then you might gain some more space in there to loosen that nut and get a better angle of attack.
Old Mar 27, 2020 | 05:45 PM
Zelduh's Avatar
Zelduh
+1
Spray some WD40, PB Blaster, etc, on it overnight & get yourself at least 1 line wrench. (It's a box end with a slot cut in it to slip over the line)
Edit;
Please replace that hose between the master and operating cylinder. When our 97 Pathfinder MT was around 5-6 years old, the line blew with my wife (and three kids in baby seats). It was in first gear at a stoplight & they shot into the intersection.
Last edited by Zelduh; Mar 27, 2020 at 05:55 PM. Reason: Line replacement experience.
Lithg
Jun 23, 2016 06:48 PM
07_350Z
Sep 1, 2013 07:17 AM
uniqueIllusions
May 24, 2011 09:44 AM
KantoutbreakdiZ
Sep 29, 2008 06:12 PM
