New here - slightly high idle - CEL
Old Apr 5, 2020 | 09:35 AM
JammyJC's Avatar
JammyJC
Default New here - slightly high idle - CEL
I have searched all over Google and various forums but can't find quite what I'm after...
Everything seems absolutely fine driving, the issue is something like this - as I slow for and approach traffic lights for example, I go down through the gears to 2nd then neutral from about 15mph. The revs seem to drop quickly, however they slowly pick up to around 1600-1700rpm for a second or two, before gently dropping to idle of around 900rpm.
Sometimes the CEL comes on and I notice that the idle stays around 1600rpm until I clear it with a pedal reset.
Could anyone point me in the right direction?
Thanks for your help.
Old Apr 5, 2020 | 11:17 AM
travlee's Avatar
travlee
Master
You check for stored codes....that is always the first step
Old Apr 6, 2020 | 03:18 AM
Heel Til I Die's Avatar
Heel Til I Die
If I had to guess, crank/cam position sensor. Check the CEL code. If so, replace with OEM.
Biochem7
Mar 19, 2023 10:26 AM
drumminguy81
May 19, 2014 08:11 AM
demundus
Aug 14, 2010 02:08 PM
ktown z
Apr 21, 2007 06:23 AM
gtbuzzbee
Aug 23, 2003 09:53 PM
