Tire Pressure
Old Nov 29, 2004 | 03:19 AM
vantage350z's Avatar
vantage350z
Default Tire Pressure
What is the best amount of pressure to have in the stock potenza's with stock 18's? I currently have 40psi. What do you recomend for the smoothest ride? Thanks. mike
Old Nov 29, 2004 | 04:11 AM
DavesZ#3's Avatar
DavesZ#3
RTFM
35 psi.
Old Nov 29, 2004 | 07:30 AM
King Tut's Avatar
King Tut
35 psi on the stock wheels and tires. I would go 40 psi on an aftermarket setup.
Old Nov 29, 2004 | 01:18 PM
vantage350z
thanks, will do
Old Nov 29, 2004 | 08:31 PM
Zenvy's Avatar
Zenvy
why 40 psi?
Old Nov 30, 2004 | 04:49 AM
King Tut's Avatar
King Tut
Cause they are rated to higher PSI levels and have smaller side walls. Plus the more pressure you run the less inner tire wear you will have.
Old Nov 30, 2004 | 04:51 AM
arlingtonz's Avatar
arlingtonz
what does your TPM read when you start the car up and the tires are cold? do you start them at 35, or do you want to get to 35 once the tires warm up?
Old Nov 30, 2004 | 07:46 AM
DavesZ#3's Avatar
DavesZ#3
Tire pressures should always be measured adjusted cold.
Old Nov 30, 2004 | 08:04 AM
arlingtonz's Avatar
arlingtonz
thank you, i appreciate the heads up.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
