295's on a 10.5 wheel..Will it fit without rubbing on a G coupe??
Old Jan 13, 2005 | 03:34 PM
Giovanni B's Avatar
Giovanni B
Default 295's on a 10.5 wheel..Will it fit without rubbing on a G coupe??
Is anyone running 295's on a 10.5 wheel on a G coupe or 350z? I am looking to go from a 9.5 to a 10.5 wheel (with aggressive offset) in the rear while maintaining the same tire. Will this rub?? Keep in mind that the car is lowered on JIC coilovers, has had the fenders rolled considerably, and has adjustable control arms. If anyone is running a similar setup, any input would be appreciated... -Giovanni
Old Jan 13, 2005 | 06:06 PM
Giovanni B's Avatar
Giovanni B
anyone??
Old Jan 13, 2005 | 06:23 PM
RaySur350GT's Avatar
RaySur350GT
Originally posted by Giovanni B
anyone??
What are your offsets?
It's all depends on width and offsets.
Old Jan 13, 2005 | 07:07 PM
Giovanni B's Avatar
Giovanni B
Im planning to go 19x9.5 +22 and 19x10.5 +22.
Old Jan 13, 2005 | 10:03 PM
accordfreak's Avatar
accordfreak
i'm wondering also
Old Jan 14, 2005 | 11:31 AM
FB-350's Avatar
FB-350
i think it is possible to run a 295 on a 10.5 width wheel...
i think member 'mrjdmz33' had 295's out back on his 10.5" sf challenge's.... i believe he is now running a 315 width in the rear though...
Old Jan 14, 2005 | 01:31 PM
bwzabodyn's Avatar
bwzabodyn
It's gonna rub, without a doubt... with a +22, a 275/35 BARELY clears the fenders in some cases, and doesn't in many others... so a 295 is out of the question... be prepared to roll those fenders!
Old Jan 14, 2005 | 02:35 PM
tylerdurden's Avatar
tylerdurden
It'll fit if you roll or cut your fenders. Not a chance if you don't.
Old Jan 14, 2005 | 06:36 PM
Giovanni B's Avatar
Giovanni B
The fenders have already been rolled considerably, I was just seeing if anyone is running this similar setup without any problems...
Old Jan 15, 2005 | 06:45 AM
tylerdurden
Jason at Performance runs a similar set up. His car is lower than most too.
Old Jan 15, 2005 | 08:28 AM
Giovanni B's Avatar
Giovanni B
I believe he is running 18's though..
Old Jan 15, 2005 | 09:50 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
again, totally depends on the tires.....some 275's are as big or nearly as big as other 295's
Old Jan 17, 2005 | 01:11 PM
symbolic350's Avatar
symbolic350
IM RUNNING A 315 YOU SHOULD HAVE NO PROBLEM ROLLING IN FENDERS IS A MUST -GOOD LUCK-
Old Jan 17, 2005 | 05:15 PM
Import-Tooner's Avatar
Import-Tooner
I just ordered my volk SF-Challenges in a 19x10.5 with a 275/35/19 toyo T1S tire. My car is lowered and I plan on having to roll it. I was going to go to a 285 or 295 but Figured that I would come in to some problems that's why I did what I did.
Old Jan 17, 2005 | 06:52 PM
Giovanni B's Avatar
Giovanni B
that is very true.. I'm using Yokohamas AVS Sport. After hearing about some people using 315's, I think i'm going to go ahead and go 10.5..
Old Jan 17, 2005 | 07:35 PM
accordfreak
do you know the offset of your wheels?
hulkout
Apr 28, 2017 09:00 PM
Jambo016
Sep 16, 2016 01:08 PM
