Is there a disadvantage to wheel spacers?
Old Jan 21, 2005 | 06:37 PM
Da Gimp's Avatar
Da Gimp
Default Is there a disadvantage to wheel spacers?
I was strongly contemplating getting a set of the Kosei K1 TS wheels:
Kosei K-1 TS
but tirerack says spacers are required. Should I care about this? I vaguely remember that there was some reason that spacers were bad.
Old Jan 21, 2005 | 10:30 PM
axxizzer's Avatar
axxizzer
they wear out wheel bearings faster than normal.
Thats all I can think of...
Old Jan 21, 2005 | 11:51 PM
ppw350Zunit's Avatar
ppw350Zunit
spacers adding weight?!?!
Old Jan 23, 2005 | 03:59 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
how big of a spacer is needed? If its relatively small (under 5mm), you should be fine. Any bigger and I would look into the H&R style which have integrated studs, to ensure you have enough thread to still hold the wheel on
Old Jan 23, 2005 | 10:40 PM
StefanZ's Avatar
StefanZ
This idea of spacers wearing out the bearings more quickly is misleading IMO. All a spacer does is put the tire farther away from the hub - and if you're going to a wheel that allows the inner tread block to be located farther away from the centerpoint of the car, then yes, you will create more stress on the suspension, in proportion to the thickness of the spacer. However, if your goal of the spacer is to allow a wider wheel that has a more attractive profile relationship to the quarterpanel (offset) but keeps the inner tread in the same position, or even more inbound, then there is no worry. Keep in mind, a grippier tire creates as large a variable on increased suspension stress as any spacer anyone with a Z would employ. (unless of course you go with 14" rims put entirely outside the body of the car, in which case you should be shot, hehe).
Old Jan 24, 2005 | 07:07 AM
spdu4ia's Avatar
spdu4ia
so what is the largest size spacer on the rear you can run (on a stock rim) without rolling the fenders? 20mm?
Old Jan 24, 2005 | 11:22 AM
StefanZ's Avatar
StefanZ
Beats me. It depends upon your starting point (your rim). On a 19x10 Racing Hart J8 with a 275 series tire, it is 19mm offset, so you'll have to do the adjusting math on your side.
Old Jan 24, 2005 | 05:30 PM
spdu4ia's Avatar
spdu4ia
i said on a stock rim
Old Jan 24, 2005 | 05:49 PM
leemik's Avatar
leemik
which stock rim? 17", 18" or 18" rays? I assume not the anniversary rim?
Old Jan 25, 2005 | 03:51 AM
CrazyMike's Avatar
CrazyMike
Assuming the studs are the same length between the Z and the G - I would say a 3mm spacer is max. I'm running a 3mm spacer for my winter rims (stock G35 coupe 17's) and get 7-8 turns instead of 10 without the spacer. Those numbers are before torquing, of course. If I were getting less than 7 turns, I'd have to suggest getting longer studs... So 3mm max.
Mike
Old Jan 25, 2005 | 03:54 AM
FritzMan's Avatar
FritzMan
I run 25mm bolt-on rear spacers with stock rims.
No clearance issues.
I posted pics of comparison in an old thread (about 1 year old). If you search spacers and my name you should find it.
In fact, my sig has a picture of me running the 25mm spacers in the rear.
Obadabot
Jun 18, 2023 11:31 PM
