Stickiest 19 inch tires?
Old Jan 31, 2005 | 09:32 AM
Street Visionz, Inc.'s Avatar
Default Stickiest 19 inch tires?
Any suggestions? Whats the stickiest? Ps2? GS-D3? bfg kdw-2? I need something good in dry and wet pavement, thanks.
Old Jan 31, 2005 | 09:35 AM
Chris@DTD's Avatar
Chris@DTD
The KDW2 is very sticky and it has excellent wet handling which will fit your needs.
Which sizes are you looking for?
Old Jan 31, 2005 | 10:11 AM
I need (2) 275/35/19. I know this is somewhat of a vague question, but do you think sub 2.0 60 ft. times are possible with this tire? I pulled off a 2.1 on some 255/40/17 Fuzion ZRi tires and I really need to get below 2.0.
Old Jan 31, 2005 | 10:16 AM
Chris@DTD's Avatar
Chris@DTD
It will be stickier than the Fuzion but there will be no sidewall flex. I think you'll be a little quicker on these still.
Old Jan 31, 2005 | 10:53 AM
so is it the stickiest tire that comes in the 275/35/19 size or do you have any other suggestions?
Old Jan 31, 2005 | 11:30 AM
Chris@DTD's Avatar
Chris@DTD
Yeah, the KDW is the stickiest in that size.
Old Jan 31, 2005 | 12:20 PM
hm okay.
Old Jan 31, 2005 | 05:21 PM
Clifton in AZ's Avatar
Clifton in AZ
Look at the treadwear rating. The lower the number the stickier. Nitto makes a drag radial and roadrace (stiffer sidewall) tire with a 100 treadwear. The drag radials are as good as my Kumhos 712's were in corners and can usually hook up 2nd were the Kumho's would spin all the way through second on the rev limiter. If you have severe traction issues you would probably be happier with a drag radial if tire mileage isn't an issue.
Old Feb 1, 2005 | 12:56 AM
MarquisDeSam's Avatar
MarquisDeSam
I have one thing to say...
SO-3~!!!
Stickiest I've ever used. Good luck trying to get tread life out of them though.
Old Feb 1, 2005 | 04:57 AM
mcduck's Avatar
mcduck
Is the BFG-KD available in a 19"? If so, it is even stickier than the KDW.
Old Feb 1, 2005 | 01:12 PM
Tekwon-V's Avatar
Tekwon-V
just make sure not to compare the treadwear rating to another manufacturer's.
Old Feb 1, 2005 | 04:36 PM
homiusang's Avatar
homiusang
I have only seen the KDs up to 18s. And yeah, they are real sticky.
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
