How's the ride on 245/35/19 and 275/35/19?
Old Mar 23, 2005 | 01:46 AM
Dave998's Avatar
Dave998
Default How's the ride on 245/35/19 and 275/35/19?
Hi all,
I was reading all your threads about 19" and 20" wheels, I found them interesting and, above all, I'll tell you: you're very lucky, you live in a country where mounting new wheels on a car is not considered as a murder...
Here in Italy is rather impossible to tune your car as you wish.
However, I'm fighting against them to be able to mount 245/35/19 front and 275/35/19 back, as I've seen they are probably the best choice for a better looking car without loosing drive pleasure (and safety). The wheels would be Volk TE37.
I'd like to know how's the ride with these measures and, if possible, could you tell me which are the best offsets for both the front and the back? +22?
Thank you!
Old Mar 23, 2005 | 09:02 AM
barthelb's Avatar
barthelb
Master
Can't really remember the offset. But the ride is better than stock because of the crappy tires they use. I have the Michelin PS2's and they are awesome. You won't be sorry
Old Mar 23, 2005 | 11:38 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
go for it. Once you upgrade to 19 or 20" wheel, the ride will be a bit more 'bumpy". Better grip since the tire bigger.
Old Mar 23, 2005 | 01:55 PM
zredline's Avatar
zredline
Smile
My 2 cents, go with the 19", I swear after I put on my 19" Iforge with Dunlop tires my ride improved, why? not sure, but I think it has something to do with sprung or un sprung weight.
Old Mar 23, 2005 | 02:10 PM
myz8a4re's Avatar
myz8a4re
the ride doesnt change a whole lot if your changing from the touring or track 18" wheels. if your changing from the 17's then you loose a slight bit of sidewall flex to smooth the ride. i honestly didnt notice much of a change between my factory 18" wheels & my aftermarket 19" wheels. i wouldnt change it for anything, i love them!
as far as offsets go it really depends on the wheel widths. if you are going with the 19x8.5" front & 19x9.5" rear then a 20mm offset front & rear is perfect. almost exactly flush w/o rubbing issues what-so-ever......the tire size you run also has more to do with the rim width than anything. i would recommend 19x8.5 & 19x9.5 for those tire sizes. you can get away with 8" wide front & 9" wide rear, but anything over 8.5" front & 9.5" rear looks a tad stretched, especially in the front. BUT those sizes can help eliminate potential fender scrubbing if you opt for 9.5" front & 10.5" rear rim widths....if that is your plan then go with a leaner offset front & rear closer to 28mm to eliminate the need for fender lip rolling..........
best of luck to you, you"ll be very satisfied!
-justin
Old Mar 23, 2005 | 02:31 PM
myz8a4re's Avatar
myz8a4re
plaese take no offense bubble, but the taller the rim the lower the sidewall profile wich results in less traction(unless of course you were going from a regular biased tire to drag radial or non biased drag tire) sidewall height is a big factor in traction......though your circumstances may be different as the tires condition when you purchased your z may have been worn as opposed to a new set of 19" rubber wich will have some traction......sorry to single you out, im a bit of a stickler on traction & handling statements. ive owned numerous high performance cars & like to share what ive learned over the years if i can..........
-justin
Old Mar 23, 2005 | 03:08 PM
atftrading's Avatar
atftrading
i love the ride with my toyos 245 35 18 and 275 35 19 rides btter then stock go with toyos
Old Mar 23, 2005 | 04:12 PM
Dave998's Avatar
Dave998
Perfect. Thank you, guys!
Hope to show you some photos of my car soon..!
Old Mar 23, 2005 | 04:39 PM
35oZephyR's Avatar
35oZephyR
+1
The ride on my Toyo 245 35 19 and 275 35 19 is alot smoother than my stock 17 shitenzas.
If you want to go 19 and keep the ride smooth go with the Toyo's. Their tires are fairly soft and great grip for street driving.
BTW: Why is it a "crime" to install wheels in Italy? I'm curious, is it looked down upon socially or what?
Old Mar 23, 2005 | 10:25 PM
Cyp's Avatar
Cyp
any gas mileage change with 19" rims over stock 17" rims?
Old Mar 23, 2005 | 10:51 PM
barthelb's Avatar
barthelb
Master
These guys are dead on with the Toyo experience, they are my last pair of tires. Before the TT i had those and they lasted my 19000mi. But my alignment was out and it wore on the inside to much. I could of got maybe 2000 more mi. but I wanted to try these PS2's and boy am i glad i got them. They are quieter on freeway cruises and grip like a ****. Wet Traction is awesome. I can beat it pretty good in the rain and leave TCS on and have no issues. Can't red line but i can boost pretty good. Good luck.
Old Mar 24, 2005 | 05:47 AM
Dave998's Avatar
Dave998
I'll try to explain, but there are some english terms I don't know..
Simply because here you're not free as you are in the US. If you want to change your wheels in Italy, and your (log-book - driving certificate?) is not updated with the new tire measures, you have to ask the motorization to be able to drive. This can only be made by asking Nissan or whatever to give you a permit.
Than, the motorization will check all to be sure you'll never be able to kill people, bomb cities, fart on the freeway, and so on...
I want to live in the USA.
Old Mar 24, 2005 | 07:47 AM
35oZephyR's Avatar
35oZephyR
Whoah, I never knew this.
That comes of a big surprise to me, especially from a country that produces the most exotic, insanely fast super cars.
Thanks for the info.
Old Mar 25, 2005 | 01:30 AM
Dave998's Avatar
Dave998
You're welcome! So come and take a little tour of this dumb country! You'll see both gentlemen on 600bhp Enzos and bad, ugly guys on 350Zs!
350Z_Al
Oct 29, 2020 07:44 PM
Tochigi_236
Sep 27, 2015 03:40 PM
doublej32
Wheels Tires
Sep 25, 2015 05:05 PM
glenngw3
Sep 11, 2015 05:19 AM
