Fn caliper fell off today!!
Old Apr 5, 2005 | 07:33 PM
ThumpAZ's Avatar
ThumpAZ
Angry Fn caliper fell off today!!
I cannot believe this!!!
Wife was driving the Z down the road today and "heard a noise." She then went to come to a stop in traffic and HAD NO BRAKES!!!
Turns out that the passenger side front caliper had worked loose somehow and was dragging on the ground below the car.
Luckily she didn't hit anything or anyone and was able to pull into a parking lot safely.
Needless to say, I am travelling on business and was unable to go home or help in any way except to listen to her panicked screams when she called.
Now the car is sitting at the dealer and we'll find out tomorrow if they're going to cover it under warranty... as I put the Stoptech rotors, SS brakelines and Hawk pads on the car nearly 8 months ago. And, yes, I properly torqued the bolts and used high-temp threadlocker on them.
BTW... we lost both of those pads on that side, and will probably have to have the caliper replaced... either warranty or out of pocket.
This just sucks!!
pic:
http://www.uselessfurball.com/images/caliper.jpg
Old Apr 5, 2005 | 07:35 PM
2003z's Avatar
2003z
ouch! sorry man! looks like the main mounting bolts didn't come undone, but the bolts that hold the 2 halves together. Did you even undo both of those bolts when you changed stuff out?
Old Apr 5, 2005 | 07:41 PM
GTNPU Z's Avatar
GTNPU Z
VERTEX Army CEO
Sorry to hear that man. At least nobody got hurt.
ZU L8R's Avatar
ZU L8R
Viper Sellout
Holy crap! Glad to hear she didn't anything and is alright.
Old Apr 5, 2005 | 07:42 PM
NismoGCoupe's Avatar
NismoGCoupe
If the rotors were installed by the dealer I can see them fixing under warranty but you installed them yourself so I doubt there going to cover under warranty, you would be very lucky if they do
Old Apr 5, 2005 | 07:44 PM
zand02max's Avatar
zand02max
Not covered under warranty, unless installed by the dealer. looks like your SOL.
Old Apr 5, 2005 | 08:18 PM
ThumpAZ's Avatar
ThumpAZ
The dealer told us today that if he has to replace the caliper, then he's gonna cover it under warranty. If it is only the mounting bolts, then we are on the hook for the repairs.
Incidentally... your caliper CAN come out of the wheel (should the bolts fail) with 19" wheels.
Old Apr 6, 2005 | 04:54 AM
King Tut's Avatar
King Tut
I guess its a good thing we have 4 calipers. As a precaution to avoid this happening to anyone else, I would recommend doing as you should with wheels and re-torquing the caliper bolts after a good 50 to 100 miles of driving. I am assuming the bolts came loose and did not snap. I think I will retorque my Stoptech caliper bolts this weekend as well.
Old Apr 6, 2005 | 06:12 AM
westpak's Avatar
westpak
SFZCC
I agree it is not the big mounting bolts but the two little ones that connect the two halves of the caliper, you usually undo one to swing the upper portion out of the way to replace pads, not both though, but who knows how it was done, I will be surprised if they cover it and will probably put it on installer error if not done by them.
Old Apr 6, 2005 | 07:38 PM
ThumpAZ's Avatar
ThumpAZ
Well, they were not aware of the aftermarket parts on there, so we are on the hook for roughly $550 for the new caliper and mount and labor...
one bolt backed out apparently (even with factory-style lock tight compund made specially for high temps (including brake temps), and the othe snapped after bending the mount.
Both pads were still there, and the rotor is fine, as are the pads. The pads stayed in the mount when the caliper went flying... that is the only good thing out of all this. The caliper got a good bit of road rash, and was bent on the outboard side.
This really sucks, but, as said above, could've probably been avoided with a little preventative maintenance after the bed in. Hindsight, perfect vision... yadda yadda yadda.
I am emailing StopTech to tell them what happened, mabe they'll put in a tech note to check the torque after a period of time, just like you do with the wheels after removal/replacement.
Old Apr 6, 2005 | 09:02 PM
___DJK___'s Avatar
___DJK___
Holy crap, that makes me want to think twice about messing with my car (not that I think it was your fault)
Old Apr 7, 2005 | 05:13 PM
ThumpAZ's Avatar
ThumpAZ
I still cannot understand how exactly it could have happened. But... my wife seet-talked the dealer a bit and he discounted the labor and got rid of the overnight shipping (10% of parts cost). Saving us nearly $100! The car will be home tomorrow.
I am so thankful for two things...
The Z seemingly will NOT break loose from the road under 80mph in a 90degree turn and my wife is not a total ditz and didn't write off a loss of brakes as "most likely only intermittent."
She handled it very well, avoiding the stopped traffic in front of her and whipping into a store's parking lot without damage to others or the car. It was only when she called me that she went berzerk LOL.
Good job, honey (LadyLea on the board)
Rev_Night
Nov 7, 2020 06:00 PM
ZXoltan
Brakes
19
Nov 25, 2015 04:21 AM
Dymsi
Sep 29, 2015 11:32 AM
Ace2347
Sep 22, 2015 03:12 AM
