Need help my v3 front bumper scrapes my driveway
Old May 28, 2005 | 08:59 PM
03znj's Avatar
03znj
Know it all
Default Need help my v3 front bumper scrapes my driveway
Is there anyway i can raise and lower the car? Can the tein edfc do the job?
Old May 28, 2005 | 09:27 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
try going 45 degree when you enter the driveway yet?
Old May 29, 2005 | 08:41 AM
03znj's Avatar
03znj
Know it all
forgot to mention it scrapes both ways going up and down , i havent tried the 45 degree method nither and thanks for the tip
Old May 29, 2005 | 09:40 AM
tabrizio's Avatar
tabrizio
One thing you could do is put sand or thin long piece of plywood at the bottom of the drive way. This makes the driveways slope a lot more gradual so hopefully you will stop scrapping.
Old May 29, 2005 | 11:12 AM
ssc's Avatar
ssc
aftermarket coilovers can only adjust for damper not height....if you want height adjustment you need some sort of an airbag suspension system
Old May 29, 2005 | 12:21 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
i have Initial D and the height is pretty much the same as Velside 3. I have to use 45 degree method 90% of the time when get in or out of any driveway. Work every time.
Old May 29, 2005 | 05:05 PM
2003z's Avatar
2003z
use concrete to decrease the angle in the drainage area. Just put a steel pipe across for water flow and fill it in.
Old May 31, 2005 | 05:04 AM
King Tut's Avatar
King Tut
Yep that is exactly what I plan to do once I lower my car. Screw the homeowners association.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
kyin
Oct 15, 2015 05:54 AM
