Widest wheel
Old Sep 12, 2005 | 02:24 AM
  #41
Bubble's Avatar
Bubble
-REPLICA ARMY-
questions:
1) will anything wider than 275/30/20 rub in the rear?
2) will the 9.5" fronts rub in the front?
3) whats the biggest tire I can put on 10.5" rim?
4) if i do need to modify the rear fenders to fit a bigger tire, what/how would I need to modify it, and how much bigger of a tire could I fit?
5) same question as #4, but for the front fenders?
thank you to whoever responds in advance
1. i use 285x30x20 now. No problem
2. I use 9.5 now. No problem
3. 305x25x30 or 305x20x20
4. If you drop your car too much then you will need to roll the fender
5. I don't think you can do much in front since they're already roll. Front can go up to 265x30x20 ( i have 255x30x20 now and still a bit more space to go)
Old Sep 12, 2005 | 10:55 AM
  #42
Srivero297's Avatar
Srivero297
thanks Bubble.
Im thinkin of switching my 8.5s to 9.5s in the winter then, and while Im at it I may get some wider rubber for my rear tires because those 275s are really stretched on the 10.5s.
Old Sep 27, 2005 | 02:19 PM
  #43
jp's350z's Avatar
jp's350z
another size question. My Z ia a stock touring.
1. will a 19 x 9 offset +25 with 255/35/19 rub the front?
2. how about 19 x 10 +25 with 285/35/19 rub the rear?
thanks guys!
Old Sep 27, 2005 | 02:33 PM
  #44
Jason@Performance's Avatar
Jason@Performance
Performance Nissan
that will work...
no rubbing with that set up...
Old Sep 27, 2005 | 03:19 PM
  #45
jp's350z's Avatar
jp's350z
how much for PIAA super Rozza's in hyper black with hardware
front
19 x 9 +25 offset with 255/35/19 toyo t1-r
rear
19 x 10 +25 offset w/ 285/35/19 toyo t1-r
shipped to 33194
Originally Posted by Jason@Performance
that will work...
Old Sep 30, 2005 | 02:51 AM
  #46
wayneside's Avatar
wayneside
Originally Posted by jcn30127
I wonder what these are:
that black Z has Wald 19x12's (345/30/19) in the rear and 19x11's (295/30/19) in the front...and this is what the car looks like now with the wheels on...
here is his site: http://www.wide350z.com/
Old Sep 30, 2005 | 08:17 AM
  #47
w8lifter21's Avatar
w8lifter21
Siiick
Old Sep 30, 2005 | 01:37 PM
  #48
JDMFairlady21's Avatar
JDMFairlady21
very very sick indeed
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
