Front BBK or all 4 corners???
Old Aug 26, 2005 | 06:18 PM
mysunset's Avatar
mysunset
Default Front BBK or all 4 corners???
I have been debating for a while on purchasing a BBK kit - considering Stoptech and Wilwood. In thinking about the options I am not sure which direction to go. Should I buy a full 4 wheel kit or just the fronts? If just the fronts, what have you done to the rears? Upgrade the rotors?
Old Aug 26, 2005 | 06:25 PM
drsifu's Avatar
drsifu
what's your goal?
what's your budget?
Old Aug 26, 2005 | 06:31 PM
21112's Avatar
21112
I'm not the one to answer this..but I've seen this question come up before.
I think the answer became....4 if your show....2 if your go.
And the reason was that a BBK kit in the front would be enough to stop your car unless you were pushing unreal amounts of HP. So if your tracking you just NEED the front, no need for extra weight in the rear and to waste extra dough.
If your show...then you gotta do all 4 so it looks good.
But, like I said, I'm no expert, but I'm sure one will come by and give you some more info.
Old Aug 26, 2005 | 07:23 PM
mysunset's Avatar
mysunset
Originally Posted by drsifu
what's your goal?
what's your budget?
that is a good question... I really do not track the car however I have considered it in the future. I have a Vortech bolted on now and try to keep a clean look. with the addition of my VOLK GT-V, the decision of buying a BBK has been on my mind.
As for budget... the best bang for the buck that does not sacrafice performance has kind of been my motto. I was considering the 13" Wilwood 4 wheel BBK, but considering options.
Old Aug 26, 2005 | 07:26 PM
mysunset's Avatar
mysunset
Thanks for the reply.... in thinking about it more.... my car is primarily shown than tracked. so maybe the choice is easier, but harder to swallow the extra cash. GULP!
Old Aug 26, 2005 | 10:19 PM
homiusang's Avatar
homiusang
in most cases, all you need to stop better is having tires with better traction. A big brake kit may not stop at a shorter distance compare with the stock non-brembo braking system. But it does have more heat capacity to allow u to stop w/o brake fading, so you will not cook your brakes during multiple hard stops.
If you do end up with getting BBK, a front BBK setup will more than enough in most occasions.
Old Aug 26, 2005 | 10:22 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
i would start with 2 front first. (functional) then add 2 rear later.
Old Aug 27, 2005 | 12:16 AM
imalazeeass's Avatar
imalazeeass
keep in mind that it is more expensive to get the fronts first and then add the rears than to get all 4 at once. Also, i heard that willwood is no longer making any brakes (until the owner recovers from his illness) so you would not be able to purchase any willwood brakes from brakezone or any other vendor unless they have old stock.
Old Aug 27, 2005 | 04:36 AM
ZPirate's Avatar
ZPirate
I agree with both 21112 and Bubble. The front kit is really all you need unless you are tracking the car often. The front kit makes a huge difference over stock (non Brembo). The rear adds only a little braking capacity and more heat disapation. I did the front first and then the rear. Except for the looks on the rear the front is plenty for the way I drive my car. Don't get me wrong the rear looks damn good, but it is more show than go (stop in this case).
Old Aug 27, 2005 | 05:17 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
not really. It's depend on how you deal with the vendor. Typical price for Front 14" with 6 pistons nowadays around $1900 to $2000. (Stoptech or Rotora)
Old Aug 27, 2005 | 06:58 AM
mysunset's Avatar
mysunset
thanks for all the replies everyone
bubble - any good vendors you would recommend? I have had mixed results buying from forum vendors
Old Aug 27, 2005 | 10:03 AM
ZPirate's Avatar
ZPirate
I got my StopTechs from Performance Nissan. They have been great to work with. I also bought the fronts first then the rears.
Old Aug 27, 2005 | 01:43 PM
imalazeeass
thats true.. its just easier to get better deals when u get as a whole
Old Aug 28, 2005 | 08:44 PM
MY350Z.COM's Avatar
CZP.US for STOPTECH Brakes
Old Aug 29, 2005 | 01:55 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I thought I read one of the Performance Nissan guys saying you will get the best performance out of a 14" BBK in the front and 13" in the rear... something to that effect.
They said 14" all around will not be the best performance and is just for looks.
Old Aug 30, 2005 | 05:51 AM
King Tut's Avatar
King Tut
I don't think Stoptech would sell a kit if it was just for looks. Anyways I have the 14" rear Stoptechs and I plan to be out on the track soon, and I will let you guys know how well the OEM Porsche rear pads hold up and how I feel the braking system held up.
Old Aug 30, 2005 | 06:32 AM
21112's Avatar
21112
I would figure it all depends on the situation.
If you have a fully stock car pushin 240hp to the wheels....a 14" rear kit is just for looks as a 14" front kit will be more than enough.
However, if you have a fully built car pushin 800hp to the wheels, I'm sure that 14" rear is a must to compliment that 14" front.
Obadabot
Jun 18, 2023 11:31 PM
Justin100
Nov 25, 2021 06:26 AM
