Anyone verify 285/30/19's fit on a 9.5" Rim
Old Sep 8, 2005 | 03:08 PM
barthelb's Avatar
barthelb
Master
Default Anyone verify 285/30/19's fit on a 9.5" Rim
My 275's are down to a couple thousand miles and I want to know if the 285's will fit on my 9.5" rim. It looks like they are back ordered too. Please lend your ASSistance.
Old Sep 8, 2005 | 03:27 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
what brand are you looking to get? i don't think you will have problem with it.
Old Sep 8, 2005 | 04:12 PM
eltness350's Avatar
eltness350
The Untouchable
if you go on toyo.com it say that a 285 is for a 9.5-10.0-10.5 inch rim so yes it should fit
Old Sep 8, 2005 | 04:32 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Yes it will fit. It might slightly pudge, but it is def within specs to work....
Old Sep 8, 2005 | 06:45 PM
barthelb's Avatar
barthelb
Master
It says they fit on a 9.5 rim but i was concerned by the overall tire width which was 10 or 11 I believe. I plan on getting the PS2's again. However with my driving and everything my rears are wearing twice as fast as the front.
Old Sep 8, 2005 | 09:10 PM
DIGItonium's Avatar
DIGItonium
Do you have 245s up front? My front wheels are 9.5" and I'm hoping to get something wider than 245s so I can get more lip protection.
I'm suffering from the feathering issue again and it's killing my front Toyos in less than 6 months! Inner treadwear is ridiculous, and everything else is fine. :-(
Old Sep 9, 2005 | 11:12 AM
barthelb's Avatar
barthelb
Master
Yes Im sporting 245's on a 8.5" rim.
I believe if you have 9.5 Front and 10.5Rear you want a maximum of 255FR and 285 Rear, i wonder if you can do a 255Front and 295 Rear. Only rubbing might be an issue depending on offset and such.
Old Sep 9, 2005 | 11:28 AM
MATTRESS MAN's Avatar
MATTRESS MAN
I've got 285/30/20's on a 9.5 and it works fine. No bulge and looks perfect. These are Falken FK451's though.
Old Sep 9, 2005 | 01:58 PM
Tortuga's Avatar
Tortuga
Default Depends on tire
I would say that it depends on the tire manufacturer's specs/recommendations. I have 285/30/19 S-03's on a 19x10 wheel. Bridgestone recommends a 10"-11" rim for the 285's. I am sure other tires may let you fit a 285 on a 9.5" wheel, just check with the tire manufacturer you are going to be using. Just my $.02
Old Sep 9, 2005 | 02:19 PM
zman1910's Avatar
zman1910
Sorry to change topics Barthelb..but can you sum up what you think of the ps2's. Thanks
Old Sep 12, 2005 | 09:50 AM
barthelb's Avatar
barthelb
Master
The PS2's are awesome tires. They just cost a lot, i've put 16k miles on them and they can go another 3-4 once i mount them backwards and swap them, my camber is off a lil but I would need a camber kit. I had the Toyo T1's and they lasted 15k miles and that was before I had 440+ to the wheels. They are very quiet and have a nice firm feel around corners. I still lose traction because of obvious reasons but they provide very good grip. Im hoping the 285's will be much better.
Old Sep 30, 2005 | 08:25 AM
barthelb's Avatar
barthelb
Master
Default Update
I mounted BF Goodrich REO50A's 285x35x19 on a 9.5" rim and they look good.
See here: https://my350z.com/forum/wheels-and-tires/145041-mounted-a-285-reo50atire-on-a-19x9-5-rim.html
Old Sep 30, 2005 | 08:35 AM
wayneside's Avatar
wayneside
they will fit...
Old Sep 30, 2005 | 09:31 AM
usmanasif's Avatar
usmanasif
I checked Toyo's site last night and yes, they list 285 tires fitting on rims that are 9-11 inches wide.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
