will Eibach springs of a G35c fit the Z?
Old Sep 28, 2005 | 04:01 PM
Bahraini350Z's Avatar
Bahraini350Z
Question will Eibach springs of a G35c fit the Z?
will it?
Old Sep 28, 2005 | 05:59 PM
Inovashn's Avatar
Inovashn
gee let me think
Old Sep 28, 2005 | 06:26 PM
1nate7's Avatar
1nate7
Yes, but probably not a good idea. The spring rates are different and it won't drop it that much.
Old Sep 28, 2005 | 07:15 PM
Gsedan35's Avatar
Gsedan35
yessssss, the drop amount will be reduced by 1/2" vs what they will drop a G coupe. Honestly, they use a very high rate spread between the softer initial spring rates and the higher final spring rates. Might help rain in your oem 03 shocks, but at the loss of performance and feel.
Eibach G35 Coupe progressive springs 1.1”/1” drop on G35 coupe
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
Eibach 350Z progressive springs 1”/1” drop* on 350Z
Spring rates in LBS initial/final front 296/384 initial/final rear 316/421
You would be much better served by buying Hotchkis springs.
Old Sep 29, 2005 | 12:34 AM
Bahraini350Z
So, how much of a drop are you talking about for the Z if i used the G's?
Old Sep 30, 2005 | 09:41 AM
Bahraini350Z
anyone?
Old Sep 30, 2005 | 05:20 PM
1nate7's Avatar
1nate7
~ .5"
350z82
Oct 1, 2015 06:25 PM
