About to Order Axis Hiro's in 19, need help!
Old Oct 1, 2005 | 03:46 PM
boma's Avatar
boma
Default About to Order Axis Hiro's in 19, need help!
Hi I'm about to order some 19" Axis Hiros in Anthracite for my Z.
I'm not sure if I should get the 8.5front/9.5rear
Or the 8.5front/10.5rear
I would like to get the 10.5 but I don't want to run into problems like rolling my fenders if I get a drop, etc.
Also, what offsets should I get? I am unfamiliar on which offset to pick. I would like an offset that offers good drivability, but still have it stick out flush with the fender.
Also I don't spend alot on rubber. Which would be a better choice?
I need help please, I don't want to make a $1200 mistake or more if you count tires.
Old Oct 1, 2005 | 05:52 PM
King Tut's Avatar
King Tut
I don't think you really have offset choices with the Axis wheels. Why do you want the 10.5s? You didn't really give a reason. Please don't tell me its for a bigger lip as it obviously isn't to run a wider tire. Go with the 8.5/9.5 and use the common 245/275 combo and be done with it. It fits great and no worries about rubbing.
Old Oct 1, 2005 | 06:05 PM
Nexx's Avatar
Nexx
+1, 10.5's weigh another 3-5 pounds more then 9.5's too.
Old Oct 1, 2005 | 11:28 PM
boma's Avatar
boma
I checked on axis' site and it actually says the 10.5 weighs 26.9lbs and the 9.5 weighs 27lbs! Wierd..........
http://www.axiswheels.com/axis_wheel..._and_lips.html
Old Oct 1, 2005 | 11:51 PM
boma's Avatar
boma
Question: how does offset work?
I see two sets of Axis Hiros on ebay:
One set has 15/20 offset
Second has 20/25 offset
Old Oct 2, 2005 | 06:39 AM
King Tut's Avatar
King Tut
You can run either of those two offsets but to be safe I would run the 20/25 offset.
ablaine
Nov 29, 2016 10:13 AM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
